Thermal paste with C2D?
Discussion in 'Hardware' started by Sniper_Grunt, 9 Dec 2006.
  1. Sniper_Grunt
    Sniper_Grunt What's a Dremel?
    29 Nov 2006
    Looking at a youtube video of someone opening a lntel core 2 duo extreme quad processor, i saw no sign of any thermal paste. I am getting a (edit) core 2 e6600 for xmas :rock: however do i have to fork out for some Arctic silver 5 to go with it? :worried:
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    There's paste on the stock sink. If you're using a third party sink then you'll need paste :)
  3. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    You should use AS5 anyway though...
  4. Sniper_Grunt
    29 Nov 2006
    What's better about it? Yes it is a noobish question but this is the first processor I have ever brought on its own.
  5. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    Nah, if he's using the stock retail heat sink, then he should just apply it as-is. When it comes time to cleaning the heatsink in a few months, THEN would be a good time to apply some AS5.
  6. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    some as5 is hardly goign to break the back compared to the core2 quad :hehe:
    but you will benefit from using it. more so if you use it with a good heatsink :thumb:
  7. Stuey
    20 Jan 2005
    IF he gets a 3rd party heat sink, then yes, AS5 is the way to go. BUT if he goes with the standard heat sink, then there's no reasont to tamper with the TIM at this point.
  8. Austin
    Austin Minimodder
    16 Jul 2004
    :D I agree, only remove the standard TIM if you really have to get that 1-2'C lower or if you had to remove the HS once you've booted it up. AS5 isn't the only option though, Ceramique is at least equal to it and often cheaper (plus there's plenty of other choices, like Cooler Master pastes for example).
  9. Sniper_Grunt
    29 Nov 2006
    Ok thanks
