Cooling Thermal Paste
Discussion in 'Hardware' started by StudioRecorder, 23 Jan 2010.
  1. StudioRecorder
    StudioRecorder Mobo's need Fabo's for company!!!!!
    14 Jan 2010
    anyone got any reconmendations for some some good thermal paste (don't think the stuff supplied with my titan fenrir will be any good)
  2. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Arctic Cooling MX3, best on the market at the moment (according to temps). I personally use MX-2 because it's only a fiver per pack
    The Bit-tech favourite is Arctic Cooling Silver 5 (or AS5) because it's cheap(ish) as well as being good performance
  3. total zombie
    total zombie What's a Dremel?
    2 Nov 2009
    ive been using akasa 450 silver based, on my coolers temps have been good.
  4. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    I wouldn't dismiss the supplied stuff out of hand; the stuff that came with mine (admittedly a rather pricey cooler) is excellent. Otherwise AS5's good stuff.
  5. flamin9_t00l
    flamin9_t00l 1,000,000,000,000 Bytes Free!
    4 Jan 2010
    Agreed. Spreads quite well for an even layer aswell.
  6. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    Arctic Cooling MX-3
  7. Fazed
    Fazed Minimodder
    5 Jul 2009
    AS5, MX-3 and OCZ Freeze. I'd class these as the best performing TIM's based on experience, there really is only a negligible temp difference between them. Personal preference for AS5 as I've used it for a couple of years now.
    However, if you want the ultimate and don't mind paying a bit more...
    Cool Labs Liquid Pro
    IC7 Diamond Paste
    Both will apparently knock about 5 degrees off AS5 under load, but supposed to be an arse to apply.
  8. Frohicky1
    Frohicky1 Awaits his moosey fate . . .
    16 Apr 2009
    I agree IC7 Diamond Paste is well worth it. Liquid Pro, on the other hand, is the most awful thing ever devised by human hands, and should only be used at gunpoint :D
  9. Fazed
    Fazed Minimodder
    5 Jul 2009
    I have to admit having a liquid metal so close to my motherboard would be pretty unnerving:jawdrop:
  10. Teelzebub
    27 Nov 2009
    I used the IC7 Diamond paste on my i7 it's really thick I used a hair dryer on the tube first made it a lot easier to use ,
    Its a bit expensive but you dont use much and it work's well .
  11. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    the titan TIM (royal grease for some reason) isnt bad. i went from that to MX3 and gained maybe 2-3 degrees.
  12. StudioRecorder
    14 Jan 2010
    cheers guys for all the input. think i'll go for the mx3:thumb:
  13. craig3000
    craig3000 What's a Dremel?
    8 Jan 2010
    I like to use OCZ extreme, that stuff is ace, not sure how easy it is to find atm though
