Hardware Thermaltake Jing Review
Discussion in 'Article Discussion' started by Claave, 2 Mar 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    That's fugly o_o
    shame about how crap it was as well
    (cost vs performance)
  3. Sketchee
    Sketchee Suddenly, looters! Hundreds of 'em!
    23 Oct 2010
    JING!
  4. Ljs
    Ljs Modder
    4 Sep 2009
    Really like the seperate scores for different platforms instead of lumping it just into one category...
  5. Kasius
    Kasius Bringing the dremolition
    16 May 2003
    Still waiting for the Frio OCK :)
  6. GiantKiwi
    GiantKiwi What's a Dremel?
    6 Jan 2011
    +1
  7. Flanananagan
    Flanananagan What's a Dremel?
    1 Jan 2011
    Sorry but I'm confused, how can the same fan have different ratings for different sockets? Or am I missing something here?,,,
  8. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    ^Newb, lol.
    Different sockets generate different amounts of heat & in different places under the heat-spreader, hence, the same cooler can perform differently on different sockets ( heat pipe locations & spacing being critical quite often ).
  9. Jipa
    5 Feb 2004
    It isn't fugly, it's different. And, frankly, I mean it. If you want a omglol killer black cooler, you've got plenty of options, just about every cooler looks exactly the same. Kudos to Tt for doing something different for a change.
    And yes, it is nice and quiet.
  10. Claave
    29 Nov 2008
    Also, different sockets have different mounting requirements, leading to different mounting mechanisms which can vary in quality, compatibility and effectiveness.
    Also also, it's not a fan :)
  11. red4our
    red4our ¿Qué es un Dremel?
    13 Jan 2011
    Nope...its definitely UGLY ;o)
  12. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    what about the noctua coolers.. thought they were the best right now
    oh nm xD just skipped to the results in the noctua NH-D14 article
  13. karagiosis
    karagiosis Greed
    17 Jan 2011
    Did you use a i5 2500k or a i7 2600k ?
  14. do_it_anyway
    do_it_anyway Minimodder
    24 Apr 2009
    Not sure if this is a typo, or if you genuinely did this......?
    But on the AM3 chart you have included a score for the reference intel cooler
    (And I quite like the look. Its different and unique. And thats why the magazine isn't called "standard beige box-PC" and Bit-tech's description on google doesn't say "The latest technology, hardware and game reviews and case mods tips on keeping every machine looking the same
  15. Combatus
    Combatus Bit-tech Modding + hardware reviews Staff Super Moderator
    16 Feb 2009
    Sorry, well spotted, it's a 2600K.
    Corrected! We did indeed use the AM3 reference cooler and didn't use our ninja modding skills to somehow fit an LGA1155 cooler onto a Socket AM3 motherboard :D
  16. morkfromork
    morkfromork Minimodder
    2 May 2010
    Totally agree with the above. Well all but the nice looking part. But fair play to Tt for doing something diffrent. Not sure it matches with the blue motherboard that well though.
  17. karagiosis
    karagiosis Greed
    17 Jan 2011
    I said that in another post and i will say it again: it would be awesome if BT could retest the best socket 1156 coolers with a socket 1155 processor as the new architecture has a different TDP but at the same time a different OC potential...
Tags: Add Tags
