Case Mod - Complete Thermaltake Modding Trophy 2018 - Project #Neon 20
Discussion in 'Project Logs' started by samarlian, 7 Oct 2018.
  1. samarlian
    samarlian What's a Dremel?
    8 Aug 2018
    Practising how to weld acyrlic before i attempt my first cutom rez build
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  2. samarlian
    8 Aug 2018
    So first time ever making a custom rez this thing is massive 17 " x 3 1/2 "
    [​IMG] [​IMG]
  3. samarlian
    8 Aug 2018
    Changeing the rear tempered glass panel on the Thermaltake Level 20 XT to cast acrylic , etched and add a two way mirror to get that holo led lite effect
    step drill bit for the holes to fit on panel covers
    two way mirror added
    now for the top tempered glass panel with a nice mirror effect TT logo
  4. samarlian
    8 Aug 2018
    Time to cut some new panels remove the metal motherboard tray and make a new perspex one.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    fits perfect
  5. samarlian
    8 Aug 2018
    Removed a section form the bottom of the case to mount rad underneath and drain port
    [​IMG] [​IMG]
  6. Cheapskate
    13 May 2007
    Love the infinity mirror. Work you are doing is great. :D
    Pyrex motherboard tray: That would be impressive. :lol: I think autocorrect zapped you there.
  7. samarlian
    8 Aug 2018
    Yes lol i have changed it to Perspex lol thanks for feed back loads more pics to come this weekend and final build pics next week.
  8. samarlian
    8 Aug 2018
    Got loads done over the weekend , laser etched new motherboard tray and infilled white with a nice black primer to give it the gloss effect.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  9. samarlian
    8 Aug 2018
    time to bend tubing and put this rig together
    Cheapskate likes this.
  10. samarlian
    8 Aug 2018
    time for a 12 hour leak test on full loop and waterfall
  11. Cheapskate
    13 May 2007
    The kind of reservoir you can go boating on. :lol: You should have figured out how to put a wave mechanism in it. Great work, btw.
  12. samarlian
    8 Aug 2018
    thanks and the wave machine would be a great idea
  13. samarlian
    8 Aug 2018
    [​IMG] #
    Boot test done , drivers all updated installing rgb cables just and infinity mirror left to install and some cable management.
    Final build pics up first thing in the morning
  14. samarlian
    8 Aug 2018
    Final stage cable management and infinity mirror
    [​IMG] [​IMG] [​IMG]
    Final pics up this morning when there is more day light
  15. samarlian
    8 Aug 2018
    Build log complete a big thanks to all the sponsors for making this happen , this is my first atrempt at modding in the real world
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Custom waterfall rez was a challenge but worked out in the end.
  16. Cheapskate
    13 May 2007
    I can't help wondering what the res would look like with the infinity mirror effect on it... and the side panels. I wouldn't want to be in the same room with it if it was though. :hehe: You'd need handrails all over the room. "Do not look directly at the computer while standing."
    samarlian likes this.
  17. samarlian
    8 Aug 2018
