News Thermaltake unveils Water 3.0 sealed-loop coolers
Discussion in 'Article Discussion' started by Gareth Halfacree, 26 Apr 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Ripitup121
    Ripitup121 MMMMMMm watercooling....
    18 Aug 2010
    Meh.......
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Yet Another Asetek Cooler with somebody else's logo on it. Whoopee, who gives a crap.
  4. mi1ez
    mi1ez Modder
    11 Jun 2009
    Why would anyone want a dual push-pull configuration? If you have 4 fans, wouldn't you use a 480mm rad?
  5. mi1ez
    mi1ez Modder
    11 Jun 2009
    240 even...
  6. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    I would guess it's because a 480mm rad needs a 480mm x 120mm space.That's a lot in most cases.
    And while you get a diminishing return on investment, push pull is still better than only push or pull.
  7. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    an 240mm rad supports 4 120 fans (did you read the bit about the Extreme version is an 240 rad )
