Electronics thermistor temp sensor probs
Discussion in 'Modding' started by bigal, 12 May 2005.
  1. bigal
    bigal Fetch n Execute
    8 Oct 2004
    ok, simplish question, i bought a circulator, basically a pump and a heater in a box for heating water and pumping it in a circle. I will be using it to heat up a tray of water to do etching in (another tray inside the water).
    anyway, the analogue temp guage is knacked, and i have a thermistor mounted in a copper tube thing which fits in the hole in the tank the analogue sensor fitted in.. so i want to get a digital meter, gut it and shove the guts in the analogue meter (cut a rectangle in the dial) to fill the hole in the fascure)
    trouble is where to get a digital meter that suits the thermistor..
    here are some rough calculations:
    150R resistance in RTP (room temp)
    will shove in boiling water tomoz
    any ideas though.. :blah:
  2. theshadow27
    theshadow27 What's a Dremel?
    23 Sep 2004
    well, a highly technical calculus derivation yields: RE54J
    (Maplin, £8, -50-70c)
  3. bigal
    8 Oct 2004
    RE54U is not recognised, what was it BTW? :confused:
  4. theshadow27
    23 Sep 2004
    Sorry! i got so wraped up in the math that i changed the J to a U.
    Dual Display In/Outdoor Thermometer
    •Indoor/outdoor temperature
    •Memory for highest/lowest temperature
    •Waterproof exterior sensor
    •Approx. 3m of thin cable
    •Wall or table mount
  5. bigal
    8 Oct 2004
    yeah but i need to use this thermistor really...
    otehrwise i would use something like YU07H or FE33L
    thanks anyway...
    any other ideas... :worried:
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It's easy to use a thermistor to switch something at a set temperature, but to get them reading a range of temperature values you need a very complex meter. It's not a linear scale.
  7. bwgames
    bwgames Minimodder
    6 Dec 2004
    I'll agree with this.
    My whole A2 physics c/w was based around thermistors and getting a temperature reading within the context of computer temperature modding. ;)
    It is possible to create an equation that will give an approximation for the temperature, but I wouldn't rely on it.
  8. bigal
    8 Oct 2004
    i have a meter that uses a thermistor, but that is about 10k on the thermistor... weirdness.
    Maby i should just buy a kit and try to encapsulate the sensor a bit.
  9. theshadow27
    23 Sep 2004
    i left out the nonlinar part, but yeah, its hard. but a kit will be more expensive then the prebuilt meter...
    but anyway, if its in a computer you can get a SM bus chip going, but its going to have to read thrugh software.
    if you get a "waterproof" sensor, you can drill a hole in a pipe coupling and "pot" it in with 5 minute epoxy. :dremel:
    if you get the one i linked, you can compare air tempature in the case VS water temp in the case... which i think would be usfull.. maybe thats just me
  10. bigal
    8 Oct 2004
    dude, :read: (at least the first post) - its for a circulator pump system circulating etchant heating water in a jacket.
    maby i could pot the thermistor from this meter into something... will have to think that one over.. :)
    any more suggestions?
  11. theshadow27
    23 Sep 2004
    wow-- i got confused between 2 threads. :jawdrop: :blush: :duh:
    but i stand by my reccomendation:
    montitoring the etchent temp vs air temp is important. i would not place the sensor directly in the etchent path, but rather cover it in teflon or something, before you shove it thrugh the hole and pot it with epoxy. etchent isnt that bad, untill it hits metal. gluing it to the outside of the tube wouldent be too bad, but it will be much slower to get temp changes.
    sorry! :wallbash:
  12. bigal
    8 Oct 2004
    it will be monitoring the water temp, this will be in the circulator unit itself.
