CPU Thermo Paste With i7 3770K OEM?
Discussion in 'Hardware' started by gtiboy, 21 Jun 2012.
  1. gtiboy
    gtiboy Minimodder
    25 Apr 2008
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    No, OEM chips don't come with thermal paste. That stuff's supposed to be good I think. Most well known brands of thermal paste perform very similarly. I personally use Arctic MX-4
  3. gtiboy
    gtiboy Minimodder
    25 Apr 2008
    I read somewhere that you cannot remove the compound on the Intel processors due to warranty?
    Does that apply to retail version only?
  4. noizdaemon666
    15 Jun 2010
    I think you're referring to the thermal paste that sits between the cores and the IHS on Ivy Bridge processors. That's a different thermal paste. The stuff that sits between processor and cooler comes pre-applied to retail chip coolers, never to the chip.
  5. Williz
    Williz Minimodder
    9 Mar 2012
    Basically, no . You're fine changing the thermal paste.
  6. Big Elf
    23 Apr 2009
    I wouldn't recommend using the Liquid Pro if you want to keep your warranty. If you need to remove it you have to scrub it off with wire wool or lightly lap it. In either case the CPU markings will come off.
  7. gtiboy
    gtiboy Minimodder
    25 Apr 2008
  8. Big Elf
    23 Apr 2009
    No, but you need abrasives to remove it completely. It's a very good TIM and better than most but can be matched with Prolimatech PK-1 or Phobya HeGrease.
    MX-3 was withdrawn, I think due to inconsistent batches.
  9. karagiosis
    karagiosis Greed
    17 Jan 2011
    I have the MX-4 and it's good but a little hard to spread. It's said that MX-2 is better and cheaper, though.
    I agree with Big Elf. I would stay away from Coollaboratory Liquid Pro unless the best temperatures are required.
