Electronics Thickness on cables
Discussion in 'Modding' started by olle, 9 May 2006.
  1. olle
    olle What's a Dremel?
    26 Nov 2005
    How thick cable must I have if i gonna extend the cables on the psu?!
    To thick, and the resistance get higher to?!
    Sorry for the noob question :wallbash:
  2. gideon
    gideon What's a Dremel?
    27 Feb 2006
    #22 i believe not very sure it should be displayed on the cables itself, wait for some more posts i'm not 100%
  3. z4114
    z4114 FACE!
    25 Jun 2002
    The thicker your wires the less resistance there is. Why that is I don't know, but its the law. As for what gauge the PSU wires are... couldn't tell you, snip one and take it to your local circuits shop and compare.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The wires are usually 18G on the molex wires, some of the other 5V, 12V and 0V may be 16G.
    Why is thicker wire lower resistance? Why does a 4-lane highway have less resistance to traffic flow than a narrower road? ;)
  5. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    Voltage is speed. Traffic is current. All them people rubbernecking at a roadside accident are the load. I am the walrus :D
  6. bender386
    bender386 What's a Dremel?
    5 Jan 2006
    goo goo g'joob.
    when i was younger i always thought it was the other way so i would look for the smallest wire i could find. ah the stupidity of youth
  7. gideon
    27 Feb 2006
    woops the #22 that was in my head is of a electric motor lying around here :wallbash:
  8. olle
    26 Nov 2005
    Thanx dudes! I,m going to my wire dealer with a piece of cable...
    I have find some cables with transparent coating, looks really cool.
    Any suggestions on how to mark them up? Maybe some colored tape?
  9. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    In uk that 1.5 mm diameter core (or 2.5mm)
    1mm = 5Amps ac
    2.5mm = 25Amps ac
    so i think youll prolly want 2.5mm 2core and earth(3core) flex but you may find most pcs may have 1.5 mm.
