Small Form Factor Thinking about an e-cube
Discussion in 'Hardware' started by Taznc, 20 Aug 2004.
  1. Taznc
    Taznc What's a Dremel?
    4 Jun 2004
    Hello,
    I have be thinking about buying an e-cube barebone system, model EG65BK.
    I was wondering if any of you have one or have used/setup one. Is it a good system? Does it get to hot? I like to play games, but im not a heavy gamer, so I don't think heat would be to big of an issue. Any help would be appreciated.
  2. FanatiK
    FanatiK What's a Dremel?
    25 May 2004
    Here is a nice link for you. Just be warned it is a long read over 1500 posts in one thread. I have an ecube and i love it. It is different than anything else. I does run a little hot but most of us found a way around this. We put a fan on the side of the case and then on the video card side we drilled holes to cool of the card. The only downside of the ecube is that there are no overclocking options in the bios and it was found out that you cant put a 6800gt in it because the psu cant handle it. If you want more info go through the thread. Lots of info but you will learn alot.
    http://forums.sudhian.com/messageview.cfm?catid=45&threadid=41582
  3. Taznc
    4 Jun 2004
    okay thank you :)
