Scratch Build – In Progress Thor D3sk V2 (Remodd 2014)[Update 20.10.2014 Bitspower Motherboard Waterblock]
Discussion in 'Project Logs' started by jojoharalds, 12 Jun 2014.
  1. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    Hi everyone,
    Like some of you may know,i made the thor desk last year 2013(wich got me the build of the week on linustechtips)
    After using the desk for almost a year now,i thought to myself,lets make some changes(since there were some things i always wanted to change,
    and i wanted to do it with acrylic Tubing)
    So i will be sharing that process with you,i hope you will like it,i certanly love doing it ;)
    ToDoList:
    1)Lower the legs
    2)More Radiators,for better cooling
    3)Acrylic Tubing (A must have if you have done it before)
    4)All the fittings alike(the last time i went with what i had,EK,Bitspower and koolance)now only bitspower
    5)Extra Compartment for poweradapter with 10 connectors ,Router,and External HDD's)
    6)SSD mounting cage (build into the Wall of the desk)
    7)Usb Connection on the outside of the Case(i have to see with that when i get further along)
    8)Cutom Acrylic Motherboard tray wit LED
    9)New Fans From Corsair (Corsair AF 120 LED blue)+
    10)Vandal Power and reset Button
    11)Drain and Fill Port ( A must have on any watercooling Pc,makes Live alot easyier)
    12)And probably find some more ideas as i go (wich i will of course keep you posted on)
    SystemSpecs:
    CPU:Intel 3770K OC 4,9Ghz (Update to 4790k)
    RAM:Corsair Dominator Platinum 1866Mhz OC 2133Mhz@1,6v
    MB:Asus Sabertooth Z77 (Update to Asus Maximus VII Hero )
    GPU:Asus 7970 DCII Crossfire OC 1200\1600mhz
    PSU:Corsair HX1000i
    HDD:Western Digital Green 1TB (probably change that out for the black in raid)
    SSD:2 x 120GB Samsung 840 pro RAID0,2 x 120GB Corsair Force LS RAID0,
    FANS: Corsair AF 120 Blue Led,Corsair SP 120 High flow,
    WaterCoolingSpecs:
    CPU:Ek Supremacy Clear Plexi polished (copper interior)
    GPU:EK DCII Block
    HDD:Bitspower Silver shining,
    RES:Bitspower 350ml Clear pexi
    FITTINGS:primochill Revolver Silver
    ADAPTERS:Bitspower 90° Silver shining,Bitspower 90° single rotary Silver shining,Bitspower black extenders,Bitspower Plexi T Adapters,
    TUBING:primochill 10mm ID / 12mm OD,Shackemodz 10mm OD/12mm ID,
    PUMPS:2 x Alphaclool VPP655 (with EK D5 X-Top Acetal Pumptop )
    RADIATORS:EK Coolstream PE 240mm,EK Coolstream PE 360mm,EK Coolstream XTX 360mm,BlackIce GTX Extreme 360mm
    SENSOR:Bitspower Flowsensor Silver shining.
    Bitspower Full board waterblock for VII Hero With Bitspower armor :)
    And maybe i will go shop some more as i go.
    Sponsors:
    BEFORE 2013:my Appologies for bad Picture Qualaty/didn't have my 650D than,Future Pictures will be Better.
    STAY TUNED!!!
  2. jojoharalds
    30 Apr 2014
    Here are the radiator mounts (since i wanted to put in some extra cooling,
    240 and 360 EK PE Coolstream side by side,since they are quite slim i was abler to put the in the small compartment where the powersupply will be.
    And I already shortened the legs ,since i want to be able to mount 2 extra 24" screens on top of the 2 x 27",
    so i dont want to have the setup to high,took off 10cm .
  3. jojoharalds
    30 Apr 2014
    HUGE Thank you To Corsair for beeing so kind and sending me this Carepackage.
    LOVE IT!
  4. darknessblade
    darknessblade What's a Dremel?
    23 May 2014
  5. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    Oooooh goodies! And dat desk!
    Looks great :)
  6. jojoharalds
    30 Apr 2014
    SSD Drive Cage for the 2 Corsair drives (in Progress)
    And i came to a conclusion ,
    its dabgerous to go shopping :)
    I needed one drill bit,
    bought the one ,but ended up with a whole set extra,with about a hundred bits ;)
  7. jojoharalds
    30 Apr 2014
    Work in progress on the motherboardtray.[​IMG][​IMG]
    Sent from my LG-E975
  8. jojoharalds
    30 Apr 2014
    here are the parts in progress for the compartment under the desk,
    had to put on some Wood dye,so the colours match.'
  9. jojoharalds
    30 Apr 2014
    Working on the Door for the Underthedesk Compartment for router and power adapter.
    This will be the door handle.
  10. jojoharalds
    30 Apr 2014
    Under the Desk compartment almost done (on the Thor D3sk)
    Some Detail work left.And maybe integrate some more ideas.
  11. jojoharalds
    30 Apr 2014
    Started on the interior of the compartment under the Desk,power adapter installed(but still have to route the cable somewhere nice)
    and lightning adapter mounted on the wall as well(this will be much cleaner than the previous Thor D3sk V1)
  12. jojoharalds
    30 Apr 2014
    Doing some work on the Thor D3sk,Cablemanagement holes,for the 24pin,8pin cpu,and 4 8pin Pcie,
    altough i think i will have to change the Pcie hole because i am not sure exactly where i will route them exactly.
  13. jojoharalds
    30 Apr 2014
    Hey everyone here a small gadget that just arrived,
    since i am still waiting on the powersupply i will just be waiting and stocking up on tools,
    Well now for the Gadget,this is the GOverlay LCD display,fully programmable.
    I was looking for a small display on ebay (because i like to see the status on my Heat of the Cpu Gpu ,)so after some browsing and searching around,i stumbled on this .
    It is fully compitable with AIDA64,and hardwaremonitor,and you are able to get a lot of other
    Plugins,
    It also has a gaming mode,wich means when you enter sertain games it will show you certain information about that game,
    best application to make use of this will probably be Need for speed,the hwole display can become a Speedometer.
    I hope to bring some more build updates soon,
    Keep you posted,thank you for checking out my log.
    Stay tuned.
  14. jojoharalds
    30 Apr 2014
    Painted midplate.with clear coat.[​IMG][​IMG][​IMG]
  15. montymole
    montymole Rigid Tubist
    24 May 2010
    i do love what your doing here :)
  16. jojoharalds
    30 Apr 2014
    Thank you.its a first time i use a router,hopefully the next time i will get it more clean.
  17. Imfaceroll
    Imfaceroll What's a Dremel?
    27 Jun 2014
    Hey mate nice build, love your progress. One question, how did you go about getting sponsors? Do you seek them out or do they seek you out? Because I have made one of these desk builds and it cost me loads haha and I am about to start a second build inside of a cabinet, so I imagine having these sponsors will save you a bit of money. Heres my build log for the desk I made if you wanted to see it. http://forums.overclockers.com.au/showthread.php?t=1132057
  18. jojoharalds
    30 Apr 2014
    Thor desk Radiator installation in progress,i decided for the look of things to put my blackice gtx in the back and use the 360pe from ek in the front,[​IMG]
  19. jojoharalds
    30 Apr 2014
    Well got some work done the past 2 days,here are some pictures,
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  20. jojoharalds
    30 Apr 2014
    Filling the loop!
