Hardware Three multi-channel fan controllers tested
Discussion in 'Article Discussion' started by Tim S, 15 Aug 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. capnPedro
    11 Apr 2007
    Honestly anything >~£12 is not going to be bought by me. Am I the only person who finds the "features" scores skewed in this article? IMO a fan controller should allow you to speed up/slow down fans, anything else is just feature creep and a waste of money.
    Bah, humbug and such!
  3. Dave_M
    Dave_M What's a Dremel?
    29 Jul 2007
    They all fail to control the speeds automatically, as well as automatically turn the fans off when not needed. I could build a better one myself.
    +1 Bah, humbug :p
  4. SpeedLegion
    SpeedLegion Minimodder
    23 Jul 2009
    I'm curious why you chose to review the Scythe Kaze Q, instead of one of its big brothers?
    The Scythe Kaze master and master ace are not much more expensive then the NesteQ FanMax 8 but offer temperature and RPM monitoring and alarms on the ace, which can be disabled if you find that annoying.
    £31 is the cheapest I found the Ace model http://www.cclonline.com/product-info.asp?product_id=32312&tid=frooct#
    Just seems strange to compare such different fan controllers. The zalman is overkill though agreed :)
  5. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    <3 ZM MFC-1 Plus
    The Kaze Master seems to be pretty good too.
  6. Sir Digby
    Sir Digby The Supprising Adventures
    18 Jan 2009
    Agreed :thumb:
  7. SpeedLegion
    23 Jul 2009
    +1 :)
  8. mclintox
    mclintox Eat cheese!
    15 Nov 2008
    Plus one more,in use now
  9. tin can
    tin can What's a Dremel?
    5 Aug 2009
    Another +1 for the ZM-MFC1 Plus. Though I've never worked out why fan 2's LED doesn't illuminate - is this the same for everyone else using one?
  10. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    According to CCL the Kaze Q has been discontinued!
  11. Toka
    Toka Minimodder
    19 Nov 2006
    linky
    Any of the fan controllers by this company.... Same sort of price as the Zalaman and much more feature rich :)
    thehippoz likes this.
  12. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
  13. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    now that i could get into, invisible from the outside of the case and does everything for you
  14. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    mrbens: I think the chrome frame on the Ace looks tacky.
  15. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    that's tight toka- run off software
  16. SpeedLegion
    23 Jul 2009
    I'm picking up my Ace on Monday, can put some pictures up for you if you want a better idea of how it looks in the "flesh"?
  17. mrbens
    15 Aug 2009
    Thanks, that's what I thought too. I prefer the plain glass like look of the normal one but hope it doesn't look plasticy. Since the ACE is brushed aluminium it may look smarter but I don't like the frame around the screen. If anybody has them on the TJ07B-W already, please take a pic :)
  18. wyx087
    wyx087 Multimodder
    15 Aug 2007
    buy Zalman fanmate for ~2 pounds, cut all the fans you are going to use and re-solder them onto one connector, plug into zalman fanmate and done!
    that's what i did with fans that i want for lower constant speed. all those fan "controllers" are essentially just variable resistors.
    take zalman for example, it have the temperature sensor, but doesn't use it to allow for automatic control.
  19. Combatus
    16 Feb 2009
    +3 for the ZM MFC-1 Plus. Dunno what Zalman are thinking with these LCD display controllers. Over complicated, over specified and over priced. ZM MFC-1 Plus on the other hand is exactly what most of us are after. I did like the NesteQ though ;)
  20. mrbens
    15 Aug 2009
    Yeah fanmates are great, I have 4 in my current PC with the controls stuck to the side of the case for easy access to the dial but want something more proffesional looking with temperatures on screen in my new build. Just waiting on full Lynnfield reviews and availability.
    If you want automatic control then check out Scythe Kaze Server: http://www.quietpc.com/gb-en-gbp/products/casefanaccessories/kaze-server
    Yes please to the pic SpeedLegion. Which case are you using?
Tags: Add Tags
