Modding Thrustmaster LCD on VGA - Got a picture :-)
Discussion in 'Modding' started by ZeluR, 1 Dec 2005.
  1. ZeluR
    ZeluR What's a Dremel?
    25 Oct 2005
    Hi,
    As my Thrustmaster LCD was not able to run from the S-Video, I've got an Radeon 7000 PCI that I try to work with the VGA.
    I've follow M pro's guide and made a cable like he have done.
    But I can't get a decent picture.
    I wonder If I need to build a Composite sync circuit for my Radeon 7000?
    I've tried also to connect +5V to pin 10 on the LCD but that didn't chance anything.
    Is there a better cable layout to build to get it to work better?
    Right now the picture is flickering as a strobe light.
    Cheers
  2. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    not that ive ever done it, but from reading the guide, it sounds like either a refresh rate problem, or a problem of sync, so double check those?
  3. ZeluR
    25 Oct 2005
    I've played around with Powerstrip and wonder what the Interlaced do?
    I've got some funny picture when I tick the Interlaced and Composite sync.
    The picture is steady but it look like it's many picture on the screen, anyone know what I do wrong?
    Here is a picture
    Cheers.
  4. ZeluR
    25 Oct 2005
    I've got some picture after spending hours with PowerStrip.
    But I have problems to resize the picture in vertical (it's to big), anyone know or can give me some suggestions?
    Here is the picture I got now.
    And here are my PowerStrip settings.
    Using M Pro's cable.
    Cheers.
  5. Bobthebeerdude
    Bobthebeerdude What's a Dremel?
    5 Dec 2005
    Well that many pictures has been a common ocurance before my new montier. It is your screen resolution settings. Turn them down and you'll be good! And i have a question of my own. I have a spare LCD from a laptop that i wanted to do that with but where did you find a guide on how to get power for the LCD....or how'd you do it?
  6. ZeluR
    25 Oct 2005
    So I can't run my main screen in 1280x1024 with the 5" LCD at 640x480?
    Do I've to set my main to 1024x768?
    Cheers.
  7. Nexxo
    23 Oct 2001
    No, you should be able to set your main screen at any resolution it supports, without this affecting the second screen.
    The only way I know to resize the picture is in Powerstrip.
    And Bobthebeerdude: you cannot hook a laptop LCD up to a desktop PC graphic card. It is totally different from a PS1 screen and would require a very specific (and very expensive) interface circuit. Just forget it. Trust me.
  8. ZeluR
    25 Oct 2005
    Thanks Nexxo for your answer.
    Wonder if it could be the cable or maybe I should try with another version of PowerStrip.
    I'm running ouf hope.... any suggestion what to try with.
    Cheers.
  9. ZeluR
    25 Oct 2005
    I'm almost there... after some more hours.
    The picture is not 100% steady and it's "jumping" up and down little, and on the top it's more "distortion" in horizontal.
    Any suggestion what values in PowerStrip I should try to adjust? I almost don't dare to touch anything... now when I've got a picture on the hole lcd.
    New setting in PowerStrip
    And a bad picture of the lcd screen (hard to take a good picture).
    Cheers
  10. ZeluR
    25 Oct 2005
    I've got a steady picture now, but I need some help on what I should try to adjust, still some distortion at the top.
    Cheers
  11. ZeluR
    25 Oct 2005
    :rock: :rock:
    Finaly I've got it, I'm happy with the picture on my lcd now.
    And Nexxo's Samurize is :thumb: , have to install my Swissflow to get the Coolant working.
    Cheers
  12. FanatiK
    FanatiK What's a Dremel?
    25 May 2004
    Could you post what you did to get it working? I know many people in the future might have the same problem and it would be nice for them to get help from this thread. Congrats on the getting it working. I need to try out Samurize one day.
  13. ZeluR
    25 Oct 2005
    I'm using M pro's Cable Layout and with the RGB ground to LCD pin 7.
    And it's hooked up to my second card (Radeon 7000 PCI).
    Here is my PowerStrip settings. Play with the settings, it takes more than one tries to get it to work, I spent some hours with the settings before I got a picture... So don't give up.
    Good Luck all of you.
  14. Dekode
    Dekode What's a Dremel?
    28 May 2005
    Hey there, Ive got the same screen, could you take a picture of your wiring please?
    Im trying to figure which plug to wire ontop on the LCD side :sigh:
  15. ZeluR
    25 Oct 2005
    Here is a pict, hope it helps. Some wire are stil left when I tried different wires (it look like sh** right now). I'll use a PsOne Cable that have the connector that fits in the gray socket, then I will remove the yellow power and the black connector so I can mount in a box or something else...
    Let me know if you need more picts.
    Cheers
  16. Dekode
    28 May 2005
    Thanks, can you give me the pin numbers,and what each cable is etc you wired it to (to your LCD End)
    My LCD is running, but I soldered ontop that black thing, and my lcd is just making lines, Ive tried changing the settings in powerstrip :(
    So Im guessing my wiring is wrong
  17. Dekode
    28 May 2005
    http://www.gpforums.co.nz/attachment.php?s=&postid=4648331
    Ive got it running, however, screen is rather green, and its rolling
    Also it doesnt autodetect the screen, I have to use another mointor then hot swap to the ps1 lcd, how did you over come that?
    You got msn btw?
    PM your msn :)~?
  18. ZeluR
    25 Oct 2005
    I bought a second Graphic card (Radeon 7000 PCI), don't know if there is any mod to make so it will autodetect the LCD on your main Graphic.
    Here is some info on the pin out on the LCD and Wire info I use.
    Here is info on what is what....
    The main problem is PowerStrip, it's hard to find the settings (I spent several hours). Don't know if it's any different with PowerStrip versions, but I use version 3.30 build 366.
    Don't give up :thumb:
    Cheers
  19. Dekode
    28 May 2005
    How did you get it to detect the mointor?
  20. ZeluR
    25 Oct 2005
    I'm using 2 Graphic card, Main (Radeon 9700 Pro) is for my 17" LCD, and the second one is just for the 5" LCD (Radeon 7000 PCI). So I guess you have to buy another card so you will have a second one just for the 5" LCD.
    Cheers
