Time for new computer
Discussion in 'Hardware' started by pranks7er, 23 May 2007.
  1. pranks7er
    pranks7er mange tout
    25 Dec 2002
    Time for a new computer my old one is obselete.
    Ok help me make decisions to be honest i not upgraded my computer in years kinda got distracted from it etc.
    Help me fill in this section, for a good mid range gaming system
    What i need:
    Processor :______________
    Motherboard:____________
    RAM:______________
    Hard disk(plenty of space form old system)
    Video Card:______________
    Can anyone give me suggestions on what they recommend, ive about 300quid to spend on these parts not much i know but im sure it can be done
    i want it mainly for games such as Stalker, new halflife releases etc
    Thanks for your help im kinda out of the loop at mo and need get back in
  2. kingdavies
    kingdavies Minimodder
    29 Aug 2004
    Hmm a little bit over
    If you are using old hard drives you might have a problem if they are IDE as these new motherboards only have one IDE socket (2 IDE devices)
  3. pranks7er
    25 Dec 2002
    not bad actually what store that from?
    whats that card liek would you recommend it?
  4. Guest-16
    Guest-16 Guest
    E6300 and 2GB of ram? Or E4300 and overclock?
  5. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    It's scan.co.uk and the card is pretty good, especially on your budget.
  6. trig
    trig god's little mistake
    10 Aug 2006
    second that
  7. bumfluff
    bumfluff What's a Dremel?
    18 Aug 2006
    You can't second a question. I would say go with the 6300 as it is in your budget and it gives better performance out fothe box than the 4300.
  8. Guest-23315
    Guest-23315 Guest
    E6300, 2GB of 5400-C4 (about £50 off scan) and an 8600 GT.
  9. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    Gotta agree with Mankz. The revision of Corsair 5400-C4 I've had experience with clocked up to 833Mhz with a bit of voltage push. The E6300 seems to clock better with less voltage then the E4300. The 8600GT is a bit weaker, but has DX10 so it's really whether or not DX10 support matters to you. If you ever get a chance to upgrade the cooler on the 8600GT it seems to overclock well.
  10. kingdavies
    29 Aug 2004
    Also dont forget you will probably need a new PSU
  11. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    I'm going to agree (most) with kingdavies on the specs for the price tbh (though I'd settle for 2GB of 667 (PC5400) myself rather than 1GB of 800).
    I'd also be inclined to use a 965 chipset board (like a Gigabyte DS3) but only because I've had good results myself.
    Funny how Scan's prices really are daily fluctuations the same CPU is now £100.23 with VAT incuded, also don't forget to check to check the todayonly section after 12, they regularly drop C2D prices by a fair chunk :)
    So yeah, that's the basics of what I'd choose, just shop around for the best prices and deals, and don't forget, sometimes getting parts from several stores even after shipping, can work out cheaper than all from the same place.
    For example if you use Ebuyer and buy an E4300 you can get £10 (google checkout) off and free delivery making it a £63 CPU instead :D
  12. trig
    10 Aug 2006
    he was implying it as a statement...so yes, i can...lol
  13. Gooey_GUI
    Gooey_GUI Wanted: Red Shirts
    3 Dec 2002
    A new case too wouldn't you think?
    :confused:
