Graphics Time to upgrade for ~£170
Discussion in 'Hardware' started by wst, 20 Apr 2015.
  1. wst
    wst Minimodder
    30 Aug 2009
    Built my PC er... a few years ago. Anyway, with the advent of GTAV, my 1GB AMD HD 6870 isn't cutting the mustard. The "Normal" shadows look crap, and it runs out of memory far below 1080p (if I want a solid 60fps)!
    My CPU is an i5 2500k, I suspect I could get more out of it than the 3.6Ghz it's currently sitting at but I don't really mind if it is a bottleneck for now (I'd use this gpu in a newer build when I get around to the "big upgrade" time).
    I have a budget of ~£170, maybe a bit more if there is a small cash leap to a big performance leap. I mainly just want to be able to run GTAV a lot more prettily, at 1080p and a solid 60fps.
    I was looking at the AMD R9 280 3GB, or the R9 270 4GB, or the nVidia 270 4GB (well, 3.5 fast, 0.5 slower GB)... all of them knock the socks off my current GPU. I'm just struggling to get relevant facts on this stuff as I've been consciously avoiding looking at hardware previously to avoid "I probably need that!"-itis in previous years (when I definitely haven't!).
    So... am I better off sticking with AMD or going to nVidia, and is 3GB and more pipelines a better option for me than 4GB with fewer pipelines (but all better than my current card!)?
  2. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    Willing to go second hand?
  3. Ljs
    Ljs Modder
    4 Sep 2009
    780GTX on the MP at the moment for £180. 970GTXs have being going for just a little above that (circa £200).
  4. ak_2020
    ak_2020 Minimodder
    22 Nov 2010
    if you're looking for brand new a 280X is probably the best bang for your buck. Should cost around £170.
  5. wst
    wst Minimodder
    30 Aug 2009
    I'm ok with second hand, but I am woefully crap at knowing how people transfer money to each other on private purchases online! Bit of a luddite in that regard (could manage it though I expect!). Having a look at the 780GTX you mention, LJS, thanks for the heads up!
  6. Arboreal
    21 Jan 2011
    I've used the MP a fair bit for small stuff recently and it's great.
    Most sellers will want payment by Bank Transfer (BT) which is so easy if you have internet banking on your current account. The money will usually get to an a/c with another 'big' high street bank in 2 hours.
    Otherwise, you can use Paypal, so long as you cover the costs yourself it seems.
  7. terrorbyt
    terrorbyt MultiModder
    19 Apr 2012
    I might be wrong but I don't think the i5 2500k could possibly be a bottleneck with any sub £300 graphics card. I don't think you'd even need to overclock it.
  8. wst
    wst Minimodder
    30 Aug 2009
    Phew, the old dog might have some life in it yet then terrorbyt! I've got a Thermaltake Frio so if I run into small bottleneck issues I should be able to OC around it I suspect, heh.
  9. terrorbyt
    19 Apr 2012
    Yes, the only possible issue you may have would be playing terribly ported/optimised games which don't utilise the graphics card properly and offloads too much to the CPU (GTA IV is a prime example of this).
  10. Ljs
    Ljs Modder
    4 Sep 2009
    I was tempted myself but my pay seems to have gone down this month and I've been stiffed on a payrise. QQ.
  11. Blogins
    Blogins Panda have Guns
    3 Aug 2010
