Scratch Build – In Progress TJ-11/Level 10 hybrid scratchbuild?
Discussion in 'Project Logs' started by rwb97, 5 Jul 2012.
What color sleeving?
  1. Red
    25.6%
  2. Black
    17.9%
  3. Both
    56.4%
  1. rwb97
    rwb97 Addicted to modding
    1 Jul 2012
    Right, hit a bit of an issue in that my motherboard seems to have died out of the blue :eyebrow: Anyway, I have an RMA for a refund, and so I am going to try my hand at some ivy bridge stuvs! I plan to go for the 3770k, on a Maximus V Formula, but this may change.
    So, I plan on using this downtime to redo a few things so it looks a bit better-painting, sanding, and hopefully finishing the side panel with i/o.
    Seeing as I have some time to keep neatening things up, anything else that you would like to see done?
  2. rwb97
    1 Jul 2012
    OK! so, back with the modding right?!
    Pulled the whole thing apart, and drained the loop. One of the things I wanted to check was how well the blocks were coping since I'm using mayhems aurora coolant which has the shiny particles that flow round it, and I knew that some blocks were prone to clogging up, so I stripped down my blocks and here's how they were:
    I also opened up the chipset block, as I don't think there are any other pictures of its innards on the net.
  3. rwb97
    1 Jul 2012
    Note To Mayhem Dyes!
    So, note to mayhems: I know somwhere you keep a list of blocks and how they work with your coolants (particularly aurora) so If it helps, I can say that the XSPC Rampage IV Extreme blocks (chip and mosfet), And the Liquid Extasy Narrow Line CPU Delrin V2 work fine with Aurora Tharsis Red for 8 months daily use:thumb:
