I have a list of data, and I want to do some sort of lookup based transpose, so I can populate columns with the correct photo file names. Basically, the data is currently sorted as per columns A & B on the shot below, and I need to get it into the format of D, E, F, G, H and so on: It is more complex than meets the eye, but I'm sure it's achievable. We have tens of thousands to sort out Any ideas?
Cheers Dave, it wasn't quite right but I was able to bodge the data and macro a bit to make it do as it was told
I would use a pivot table. It wouldn't come exactly as you want, but at least it will put in a format where it should be easier to manage.
