Case Mod - In Progress Translucid Paragon (Handmade)
Discussion in 'Project Logs' started by Bogdan, 4 May 2016.
  1. Bogdan
    Bogdan What's a Dremel?
    4 May 2016
    [​IMG][/CENTER]
    Hello to everyone!
    With my first post I will introduce my first modding project based on the unique In Win Tòu.
    I would like to thank my sponsors: In Win Nederland , Aquatuning Europe, MSI Europe, Transcend, Patriot Memory and Noiseblocker.
    With In Win's 30th Anniversary, I will modify the Tòu while keeping some of its design.
    I will update the system specifications once everything is set.
    First the awsome & unique In Win Tòu:
    The original while illumination
    Now the sponsorships
    Aquatuning
    MSI, Transcend, Patriot and Noiseblocker
    The first wood has been cut :)
  2. GeorgeK
    18 Sep 2010
    Hello and welcome to the forums. Project logs require pictures of work in progress so I'll move this over to Modding until then. Send me a PM or report this post when you have some pics.
  3. Bogdan
    4 May 2016
    Here are some of the watercooling components:
    The new Alphacool Eiszapfen 13mm HardTube fittings :D
  4. Bogdan
    4 May 2016
    Update: I started cutting the wood for the side panels and for the lower corners.
  5. Bogdan
    4 May 2016
    Modding the In Win Desert Fox PSU
    The PSU has been painted matte black :)
    And now the 24Pin cable is sleeved.
  6. Bogdan
    4 May 2016
    Update: The front wood panel has been cut to shape and the writing is done.
    At the moment this panel needs to be sanded including the edges and writing :)
  7. Bogdan
    4 May 2016
    Small PSU Update, two wires one pin and one sleeve :D
  8. Bogdan
    4 May 2016
    The PCI-E covers and thumb screws are painted, tomorrow I will update on the paint used and upload more photos with these small parts.
  9. Bogdan
    4 May 2016
    The PCI-e covers and paint photos will be done for tomorrow, but for now, here is the Alphacool heatgun, totally needed for hardtubing :)
  10. Bogdan
    4 May 2016
    Update: Here is a teaser with the plexiglass :)
    Stay tuned for more! :D
  11. Bogdan
    4 May 2016
    UPDATE!
    Here is the new reservoir for this project :D
    Painted the cap, aka fitting plate :)
    Labels removed and drilled the space for the fitting
    The bottle/reservoir is connected to the pump and its block with regular flexible tubing and fittings, this way holds the whole assembly better than hard-tubing and fittings.
    The Graphics Card (GTX 660) for this case, just like in my other project, it matches the motherboard and still going strong in gaming!
    Speaking of motherboards...
    Here are the freshly painted PCI-e covers with matching thumb screws
    The Alphacool radiator is already in its place with metallic and rubber washers
    The wood side panels are done and already on the case, next I have to mount the corner small panels
    I did my first bent!
    By the way, those white spots are just dust from cutting the tube.
    Here is the system without the Power Supply and before the watercooling setup
  12. Bogdan
    4 May 2016
    Here is a teaser of the project :)
    Yes the bottle is not straight, it's a feature, if you know what I mean :D
  13. Bogdan
    4 May 2016
    Update, I've been awake for most of the weekend, here is the finished project, I still have little things to do but I have to do the other project and maybe get some sleep.
  14. Bogdan
    4 May 2016
    The interior, I had to swap the GTX 660 with a GTX 650 Ti, I had a major leak and the water went straight on the GTX 660, at the moment I am still trying to dry the GPU.
  15. Bogdan
    4 May 2016
    The Transcend SSD is mounted on a Sony floppy disk, it's a storage device on a storage device :)
