Overclocking Trouble raising FSB beyond 333MHz
Discussion in 'Hardware' started by ch424, 24 Nov 2008.
  1. ch424
    ch424 Design Warrior
    26 May 2004
    Hi everyone
    I have a GA-EP31-DS3L, a Q6600 SLACR and 2x2GB of OCZ DDR2-1066 5-5-5-18 RAM.
    At the moment it's running absolutely fine, 4 hours (I got bored of waiting) prime stable at:
    333MHz FSB, 9x multiplier 333x9=3GHz
    1.45V Vcore in BIOS, actually 1.4V after Vdroop
    RAM at 999MHz 5-5-5-18 2.1V (so within spec, it should go up to 533MHz no problem)
    EIST and C1E enabled
    about 35*C idle and 59/60*C after being at full load for 45mins.
    PCIe clock at 100MHz
    Now, what I'd like to do is run it at 354MHz FSB, giving 1064MHz RAM (as close to 1066MHz as possible). However, the system refuses to go above 333MHz. I've tried:
    Disabling EIST and C1E
    Decreasing multiplier to 6x
    Increasing CPU voltage to 1.5V
    Increasing NB voltage by +0.1V
    Increasing FSB voltage by +0.1V
    Reducing memory mulitplier so that it runs at ~800MHz
    However, the system refuses to POST. The Gigabyte website claims the board will do 400MHz FSB with overclocking, and the reviews I've seen managed to reach 420MHz, so I don't know why I can't reach anywhere near that. It won't even do 340MHz.
    Any ideas? :confused:
    Thanks for any help
    ch424
  2. wyx087
    15 Aug 2007
    try giving a little juice to the south bridge
  3. ch424
    26 May 2004
    I don't think the motherboard supports it. :(
  4. ch424
    26 May 2004
    Well, I'm not sure what changed, but I now have it running at
    400x8=3.2GHz
    FSB:DRAM=1:1
    RAM 800MHz @ 4-4-4-18
    RAM=2.1V
    MCH=+0.1V
    FSB=+0.1V
    Vcore=1.5V (1.41V after vdroop)
    Temps are hitting 60C for the cores and 50C for NB, but don't seem to go any higher. This is good, right?
    thanks
    ch424
  5. Methanoid
    Methanoid What's a Dremel?
    27 Apr 2009
    Your sig shows Intel Q6600 @ 3GHz | Asus P5QL-E
    Did you ditch the Gigabyte and why cos it looks like it clocked better than the Asus????
  6. realfakesnake
    realfakesnake lost in the wilderness
    23 Apr 2009
    That is some droop you got there.
  7. Methanoid
    27 Apr 2009
    Its bad form to tell a man he's suffering from droop !! :naughty:
    mm vr likes this.
  8. ch424
    26 May 2004
    I replaced the gigabyte because of lots of things - it only supported 4GB of RAM, and didn't have firewire. There were other issues too... I assumed the ASUS would give me better clocks and less Vdroop, but it gave me identical clocks for some reason. Maybe the RAM or my PSU are holding me back.
  9. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    those are good temps on that quad.. nothing to be worried about- the vdroop can be taken care of with a pencil mod or bios usually.. but you don't need it unless your really going buck nuts- and there's an old debate about why there is droop in the first place and why not to disable it (it basically sets a spike limit so you don't suffer electromigration from overvoltage) pretty interesting stuff, course if your out to set records you don't care about longevity =]
