Networks Trying to network with XP & a crossover cable
Discussion in 'Hardware' started by Cyberbob:-), 24 Jul 2005.
  1. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    Hi guys, I'm having problems setting up a home network.
    Got 2 PC's both running XP. Computer One has a IP of 192.168.0.1 subnet 255.255.255.0
    Computer Two 192.168.0.2 subnet 255.255.255.0.
    I'm using a crossover cable. Computer one also has internet connection Will ping computer Two But computer two won't ping computer one. Keeps timing out, switched off firewalls on both cards, still not working.
    I've even switched the cable round to make sure the cable was ok, still the same problem....Any Idea's... :idea:
    **Edit** Right I switched off Norton firewall now I can ping both ways. But on computer one I cannot still see computer two in network places.
    On computer two I can see computer one but it won't let me access it, gone into entire network, microsoft windows network,mshome. I can see both but can't access computer one. If I go into the same on computer one I can't see either...
  2. edz
    edz What's a Dremel?
    18 Aug 2003
    Got both on the same workgroup?
    try
    \\computername
    also in an address field
  3. simon w
    simon w What's a Dremel?
    3 Nov 2003
    Are you sharing anything (with guest/anonymous access) on either of the computers?
  4. Cyberbob:-)
    16 Jun 2002
    Got it sorted now, Norton firewall was stopping it....Damm thing.
    All I've got to do now is figure a way to have norton running and my network working, I've just got to look into it a bit more, Hadn't had much time to mess the last couple of days... :naughty:
  5. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Easiest way is to configure Norton to allow the IP address of the other computer. Or the mac address of the network card, then you'll be done!
    But I'll tell you that Norton isn't very network friendly.
