Modding TT Shark Window Mod! Front mesh update
Discussion in 'Modding' started by Defyant Mods, 19 Jun 2005.
  1. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    some one in a forum asked how they should go about putting a window in a TT shark case!
    I just so happened to have one sitting right here! so it hought id give it a go,
    Could be a great way for those who own sharks to actually see how good this mod looks!
    the mod took 40mins start to finish, but id say 2hrs max.
    Jigsaw with a fine metal blase, dremal, pilot drill and a hot glue gun were used with a small peice of 100g sandpaper to smooth metal edges.
    In case your not familiar with the shark :)
    Remove the side panel
    Mask up and mark out.
    Cut using a jigsaw with a fine metal blade.
    ive cut the area oout on the window so it will still have its orig intended side vent.
    Peal the protective layer off the plex and glue into place
    End result
    On the case! Sharks never looked so good! C'mon TT this should be standard :thumbup:
  2. XplicitContent
    XplicitContent What's a Dremel?
    12 Mar 2005
    I have a black Thermaltake Shark case, and this just gave me some inspiration to start working on mine, its just that I need a dremel :( . Nice job!
  3. Agamer
    Agamer Minimodder
    10 Mar 2005
    I do agree that looks very nice. Good work.
  4. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    Wow, very very nice :thumbsup:
  5. Petor
    Petor What's a Dremel?
    19 Jun 2005
    hey looks nice,
    just wondering if anyone knows where i could get the "honeycomb" pattened metal that you can see on the shark case. looks awesome. and woudl be a nice well ventelated windows replacement.
    or what it is called so i can ask for it?
    thanks
  6. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    Very nice and professional looking. I like it.
  7. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    Damm that looks good :)
  8. dibek
    dibek What's a Dremel?
    12 Jun 2005
    www.mnpctech.com
    It's called Moddersmesh.
    BTW very nice mod :thumb: Now go and paint the case interior black :D
  9. Rufus-Seal
    Rufus-Seal Guest
    looks very good! Thumbs up!
  10. ZuNe
    ZuNe What's a Dremel?
    2 Jun 2005
    :thumb: very nice indeed!
    TT definetly should make a replacement side panel for their sharks!
    Very tidy looking cuts too ;) If I didn't know already I would have guessed that it actually was a pre-mod panel.
  11. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    But if such a window was standard, you wouldn't be as proud to be a modder would you? ;)
  12. Defyant Mods
    14 Sep 2004
    HPRES2 makes me proud :) not a 40min window job :p
    but i get where your comming from cheers :thumb:
    thanx guys for the pos feedback, hope it shows other with Sharks how easy and great this case looks with a small mod :)
  13. mcbeckel
    mcbeckel What's a Dremel?
    31 Aug 2003
    Looks Killer..Great Job
  14. Florian
    Florian Minimodder
    4 Jun 2004
    Nice and clean work, but I never understood why people put in windows that show drive cages and stuff. Those are usually the least interesting things to look at in a case.
  15. Tech-Daddy
    Tech-Daddy What's a Dremel?
    8 Oct 2003
    If you can find a local sheet metal retailer, as for
    Hexagonal Mesh, 9/32 Staggered perforated
    You might be able to find some locally in your country with that description.
    :thumb:
    Excellent job DÈF¥âÑt¸.·´¯`¤!
    I've got a Shark lined up for later on, and have been thinking/drawng ideas out... you just inspired a slew more!
    Excellent work, as usual!
    :clap:
  16. jeffkim
    jeffkim What's a Dremel?
    20 Jun 2005
    Very nice mod~~
  17. Machine
    Machine What's a Dremel?
    27 May 2004
    Nice&cleen, I love it very very well done :rock: .
    --must get a shark case :worried: --
  18. Defyant Mods
    14 Sep 2004
    Cheers guys :)
    Good to hear TD :), i added this front mod aswell. its comming inside to be used as my server and adding 5 large drives to the front posed a cooling prob.....
    This isnt perm!! im waiting for some diff mesh to arrive, but you guys get the idea.
    as you can see the back of the door is 100% solid..... aircraft grade alu solid!!!
    But! you can see "above" thet the UGLY as F :rolleyes: ck plastic fascia behind does have adequate venting!
    Remove the front alu paneling
    The "Naked shark"
    as you can see the shark with its "battle armour" removed...theres no way this thing can deliver frsh air to its HDDs
    Removing the door.
    The door pulls down into 3 main sections.
    the slatting, its armour and the door itself.
    First thing is to mark out ther area where i'll be cutting fresh new holes....
    The panel masked up with the new holes cut, this job chewed thru 4 blades!!!
    this metal is tuff.. bewarned!
  19. Defyant Mods
    14 Sep 2004
    A qik test to see how it fits up.
    Next is to cut and bend to shape the 3 Grills that will replace the metal slats.
    I could do this by simply placeing a peice of mesh behind the arch.....
    but this wouldnt look pro, just an easy way out.
    the method im using here is to bend the mesh over a peice of wood.
    Using a rubber mallet to get the shape...v.ery easy with streight lines.
    testing the bent mesh.
    after mesh # 2
    Mesh #3 and the extra side peice is also replaces so it matched the rest.
    The mesh grills are held in place for now with hotglue.
    When the front panel is bolted back onto the door it will hold the grills in place..
    Next is a bit of "black backgound masking" this will hide the cuts and allow the mesh to look sharper.
    with the door mounted back on the case
    Re-attach the front panels with the screws
    Silde back in the Veritcal strips and whaala...
    With the new "windowed" side panel the shark is looking pretty darn impressive
    Slip a lite down the back and your starting to see some pretty cool lighting.
  20. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Defiant, you deserve an award for best job at "de-fuglification." That is gorgeous :thumb:
