Case Mod - Complete Tthor Ragnarok
Discussion in 'Project Logs' started by warboy, 13 Oct 2017.
  1. warboy
    warboy Insane modder
    24 Nov 2011
    Hi guys! :)
    My new mod is ispired by the film Thor Ragnarok ...
    Based on case Thermaltakce Core X71 TG Tempered Glass
    The Hardware specs:
    Case:
    Motherboard: X299 AORUS GAMING 3
    CPU: incoming
    VGA: incoming
    RAM: XPG Spectrix D40 32 Gb
    POWER SUPPLY: Thermaltake Toughpower DPS G RGB 1000W Titanium
    SSD: XPG GAMMIX S10 PCIe Gen3x4 M.2 2280
    Watercooling:
    3x Radiator: Thermaltake Pacific RL480
    2x Radiator: Thermaltake Pacific RL140 Radiator
    Radiator fans: 2x Thermaltake Riing 12 RGB Radiator Fan TT Premium Edition 5 Pack
    Radiator fans: 2x Thermaltake Riing 14 RGB Radiator Fan TT Premium Edition 5 Pack
    4x pump: Thermaltake Pacific P1 Black D5 Pump w/ Silent Kit
    Water block CPU: Thermaltake Pacific W3 Waterblock
    Tubes: Thermaltake V-tubler PETG Tube 16 mm
    fittings:
    Thermaltake Pacific G1/4 balck
    Paints:
    Wicked colors
    Createx Colors
    Acrylic transparent
    Big Thanks to:
    Start with presenting the case
    First I prepared the painting case and I started with airbrushing
  2. Vault-Tec
    30 Aug 2015
    Wow....
  3. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    That's cool the way you use the small magnets to hold the paper!
  4. warboy
    24 Nov 2011
    Thanks Guys!!! soon with more news :)
  5. warboy
    24 Nov 2011
  6. warboy
    24 Nov 2011
  7. warboy
    24 Nov 2011
    first I prepared the plexiglass panel...
    I put the cables in place and I sleeving it :)
    after I put it in the case
    what do you think?
  8. warboy
    24 Nov 2011
  9. warboy
    24 Nov 2011
  10. CodyWA
    CodyWA What's a Dremel?
    20 Nov 2017
    haha I laughed so hard to see the Grandmaster in the middle. Yes! he's the most important! :grin:
    btw, nice work mate :D
    warboy likes this.
  11. warboy
    24 Nov 2011
    Waiting for the processor :miffed: , here are some shots of the Gigabyte X299 mounted.
    With the two Thermaltake Pacific R15 radiators I will make a single tank :)
    I will use laser-cut plexiglass parts to create the various supports
    Then it will be placed on top of the case, between the two Thermaltake Pacific RL480 radiators, slightly raised ..
  12. warboy
    24 Nov 2011
    now I start to place the tubes
    then I place the grid for the fans
  13. warboy
    24 Nov 2011
    Between the two upper radiators I will position Thor's hammer :)
    I get help from my brother who turned the styrofoam into stone :)
    The base is made of plexiglass and can be removed
  14. warboy
    24 Nov 2011
    Finally the processor :)
    and mount the waterblock Thermaltake Pacific W3
  15. warboy
    24 Nov 2011
    I start to install liquid cooling :)
  16. warboy
    24 Nov 2011
    and now the final pics :)
  17. warboy
    24 Nov 2011
  18. Cristianodanna mod
    Cristianodanna mod Minimodder
    16 Dec 2016
