Education Turning plastic into oil
Discussion in 'General' started by Teelzebub, 23 Aug 2010.
  1. Teelzebub
    27 Nov 2009
    bulldogjeff likes this.
  2. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    It seems to a bit too easy TBH.
    First of all, if you could just distill plastics I would believe people would have discovered that many years ago. Also, plastics contain more than just oil. It does have some additives. Where does the additives go in the process?
  3. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    Damn I thought about doing that while I was in the shower yesterday morning! Helps reduce the oil issue, but what about the global warming/etc?
  4. Unicorn
    25 Jul 2006
    Cleaver.
    I lol'd.
  5. Freedom
    Freedom Minimodder
    27 Oct 2004
    My BS alarm is ringing.
  6. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Its nothing new, there are places in China that have been cat cracking plastic to make diesel fuel for a couple of years. I can't find the source i read it but a quick google of cracking plastic turned up loads of links.
    http://www.ien.com/ienblog.aspx?id=136733
  7. Teelzebub
    27 Nov 2009
    :lol: Thats it I'm not throwing any more plastic away, I'll just wait for them to get in the shops.
  8. genesisofthesith
    genesisofthesith complete spanner
    4 Dec 2004
    Considering oil is used in the production of plastics, how is this any better than recycling the plastic?
    Apophis54 likes this.
  9. talladega
    talladega I'm Squidward
    18 Aug 2007
    make your own fuel????
  10. chimmy09
    chimmy09 What's a Dremel?
    26 Jan 2010
    He's a WITCH!!!!!
    also...
    "and with the children there, we collect garbage..."
    is he proposing we bring back slavery/child labor?
  11. Teelzebub
    27 Nov 2009
    :lol: Well its better than what the pope does to children :worried:
  12. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    Oh come on, so fake.
    Even if it did work, just think of the energy you'd need for it to do so. You'd need to melt down the plastic, somehow remove the impurities, additives, general crap. Then you'd need to break down the plastic-oil into its fractions. All this done in a mini little machine that doesn't make your power bill go through the roof?
    (I may have tacked on the fraction part, is that supposed to be done elsewhere or is it done in the machine?)
  13. bahgger
    bahgger Minimodder
    13 Apr 2005
    I've done some research on this subject for my internship and my general conclusion was that although fuel can be made from thermochemical decomposition of some plastics (PP, PE, etc), the amount of energy used is more than just recycling the plastic into new plastic forms. I can see this being relevant if the revenue from fuel sales exceeds recycled plastic stock, but only if that is the key factor (which I don't think it is always).
    http://en.wikipedia.org/wiki/Pyrolysis#Plastic_waste_disposal
    Take a look here for details.
