Graphics TV to PC problem
Discussion in 'Hardware' started by Isuo, 11 Mar 2005.
  1. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Ok, it's me again asking stupid questions, but I know that from you I can ge good answers so...
    My problem is, that I can't get any pictures out from my tv, which I have connected with the s-video cable.
    My graphics card(which is ASUS Extreme AX300/TD btw.) says, that there is a TV connected, but the TV keeps showing the blue screen.
    I have the ASUS Hydravision drivers installed, and I think they are the newest ones available.
    And yes, I used the search before posting, but I only got 3 threads, and none of them answered my question.
    I'll apperciate all the hints and tips you people hopefully will post.
  2. smoguzbenjamin
    smoguzbenjamin "That guy"
    6 Sep 2004
    Have you tried using the S-video ->composite adapter? Most TVs will haev 3 phono plugs aswell as S-video, and otherwise use a SCART adapter. The possibilites are endless :D
  3. Isuo
    13 Oct 2004
    So should I plug the s-video to scart, and try that way?
    EDIT: I plugged the s-video in through scart and it works now.
