Linux Ubuntu LAMP Server
Discussion in 'Software' started by ufk, 28 Dec 2006.
  1. ufk
    ufk Licenced Fool
    3 Jan 2004
    I eventually got round to setting up a LAMP server using Ubuntu 6.06 LTS (dapper drake) as the base, everything so far has gone astonishingly well for a first time Linux install apart from one niggling problem..
    I have configured the networking settings as follows
    Code:
    auto eth0
    iface eth0 inet static
    address 192.168.1.200
    netmask 255.255.255.0
    network 192.168.1.0
    broadcast 192.168.1.255
    gateway 192.168.1.1
    but cannot download updates/packages from the net without pinging the IP address of the server first, basically without a ping i can't access any server....most bizarre and i cant figure it out so any suggestions would be good
    messing around in the command line has been instructive to say the least, I even managed to install webmin from it so I'm impressed with myself :clap:
  2. Glider
    Glider /dev/null
    2 Aug 2005
    Sounds like you have to set up your DNS server...
    Try putting "nameserver <IP>" in your /etc/resolv.conf
  3. splashtech
    splashtech What's a Dremel?
    26 Dec 2006
    Yeah, for some reason on my 6.06, DHCP did not set up the DNS server correctly (my router acts as a DNS relay, so that should have been used, but it wasnt). If your router is the same, just put its IP into /etc/resolve.conf. If not, put your ISP nameserver(s) into it. Should work fine then. Just remember to change it if you ever change the network setup or move the machine to somewhere else.
  4. ufk
    ufk Licenced Fool
    3 Jan 2004
    thanks for the suggestion guys, I'll have a go at adding my router IP into /etc/resolve.conf to see if that cures it.
    splashtech on a side note whereabouts in Bournemouth are you? I'm just down the road in sunny Christchurch
  5. splashtech
    26 Dec 2006
    Winton :D I'm a student at the uni.
  6. ufk
    ufk Licenced Fool
    3 Jan 2004
    Small world I work on castle lane ..winton end :)
  7. splashtech
    26 Dec 2006
    Hehe, small world indeed :)
