Ultimate Upgrade- Counter Strike
Discussion in 'Project Logs' started by Timdog, 9 Apr 2004.
  1. Timdog
    Timdog What's a Dremel?
    7 Sep 2003
    I am going to be starting a case mod to change my case into the theme of CS. I already have plans for my first mod and I took a few pictures of my designs.
    This is the front panel behind the front door of my Antec 1080B case. There will be a 80mm fan hole cut out in the bottom two front plates to allow for air flow.
    The next is an image of my front door. There will be an 80mm LED lit CS fan grill on the front with a 80mm Enermax Fan inbetween my front door hole and my front plate hole.
    This is how it should look from the side.
    Bassicaly it will go First 80mm hole -> 80mm fan -> 80mm hole with grill on outside.
    I will be posting more pics once I can get my hands on my dad's drill and hopefully get the two 80mm holes cut. It may be a little bit longer before I can order the parts.
    Any suggestions are welcome. I will be doing a LOT more mods to this case but this will be what I start with.
    This is also my FIRST modding experience EVER. So it may end up looking really bad. :eek: :worried: :blush:
  2. Xeno
    Xeno What's a Dremel?
    9 Apr 2004
    psst... I don't see any pictures. :waah:
    I was thinking of a CS MODDED CASE myself, nice thought dude! I already got a fanguard, see the picture located down. If you need any design-help, i'm willing to help :D
  3. Timdog
    7 Sep 2003
  4. Xeno
    9 Apr 2004
    Looks nice, but make sure you turn that LED-fan vertival :naughty: . At the orriginal CS logo, the fellow aims the gun to the right. :worried:. Check www.counter-strike.net to see it. :D
  5. PC JUNKY
    PC JUNKY Banned
    7 Jul 2002
    This looks very promising will stay tuned . . .
