Modding Un-adonizing a case?
Discussion in 'Modding' started by Blast, 4 Jun 2004.
  1. Blast
    Blast What's a Dremel?
    9 Jul 2003
    Is it possible to remove the adonizing from a case, paint it, and then reapply some type of clear-coat or something to protect the aluminum. I ask because I wonder if it would be possible for me to paint my Antec Super Lanboy. If this is possible, any links to products would be greatly appreciated.
  2. darkhunter
    darkhunter What's a Dremel?
    13 Apr 2004
    i dont think so
  3. Pookeyhead
    30 Jan 2004
    Why bother? It's already protected, so just paint over it as it is. Why remove the anodising first?
  4. Blast
    9 Jul 2003
    I heard that it doesn't hold paint very well if it is adonized. True?
  5. Mr.Nonflex
    Mr.Nonflex What's a Dremel?
    2 Jun 2004
    the adonized layer is thin, you should be able to sand it away. :cooldude:
  6. Pookeyhead
    30 Jan 2004
    True, but could ruin a brushed finish if you wish to retain that.
    Blast - Not necessarily, I've painted anodised stuff before with no problems. Just use a good primer coat and you'll be OK.
  7. kh15
    kh15 What's a Dremel?
    10 Mar 2004
    sanding would work yes but it would take you all day
    i would go to a local body shop and ask them to media blast it for you
  8. Fronzel
    Fronzel What's a Dremel?
    9 Mar 2002
    Oven cleaner.
  9. Gizmo1990
    Gizmo1990 What's a Dremel?
    12 Oct 2003
    Gets my vote. I did this recently and the results were top banana!
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Anodising is very easy to remove in warm caustic soda (sodium hydroxide solution), but it will leave an etched surface behind. OK for paint (with the proper primer) but not very nice clear-coated. :blah:
    From http://www.finishing.com/157/14.html :
