Motherboards Un-flashing a BIOS
Discussion in 'Hardware' started by noizdaemon666, 28 Jan 2012.
  1. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I updated the BIOS on my board and ever since higher overclocking attempts (4.3GHz and above) have proved fruitless with anything upto 1.6vcore. However before, I could use 1.55 and get 4.4GHz pretty stable.
    Is it possible to flash an older BIOS back to the board or should I just shout at it to make myself feel better? :D
    Cheers
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    In essence you can't unflash a BIOS, only overwrite it. So go ahead and overwrite the new BIOS with the old BIOS!
    Just make sure to lower all settings to non-overclock before you flash!
    noizdaemon666 likes this.
  3. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Some boards don't allow you to flash back to older BIOS versions, but there is an easy way to get around it - just rename the BIOS .rom file to the same as a newer version.
  4. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Should work fine. I had some issues flashing to an older BIOS but that was probably just Asus. There are plenty of alternative methods around if the standard route doesn't work for you.
  5. noizdaemon666
    15 Jun 2010
    Cheers guys, + rep :thumb: Hopefully 4.4GHz comes back to me pretty soon lol
