Unable to send results to server...
Discussion in 'bit-tech Folding Team' started by Tattysnuc, 7 Jun 2012.
  1. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Hi,
    I keep getting this error:
    Code:
    [23:12:44] + Attempting to send results [June 6 23:12:44 UTC]
    [23:12:45] - Couldn't send HTTP request to server
    [23:12:45] + Could not connect to Work Server (results)
    [23:12:45]     (171.67.108.26:8080)
    [23:12:45] + Retrying using alternative port
    [23:12:47] - Couldn't send HTTP request to server
    [23:12:47] + Could not connect to Work Server (results)
    [23:12:47]     (171.67.108.26:80)
    [23:12:47]   Could not transmit unit 09 to Collection server; keeping in queue.
    [23:12:47] + Closed connections
    [23:12:47]
    [23:12:47] + Processing work unit
    [23:12:47] Core required: FahCore_11.exe
    [23:12:47] Core found.
    [23:12:47] Working on queue slot 00 [June 6 23:12:47 UTC]
    [23:12:47] + Working ...
    [23:12:47]
    [23:12:47] *------------------------------*
    [23:12:47] Folding@Home GPU Core
    [23:12:47] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
    [23:12:47]
    [23:12:47] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
    [23:12:47] Build host: amoeba
    [23:12:47] Board Type: Nvidia
    [23:12:47] Core      :
    [23:12:47] Preparing to commence simulation
    [23:12:47] - Looking at optimizations...
    [23:12:47] DeleteFrameFiles: successfully deleted file=work/wudata_00.ckp
    [23:12:47] - Created dyn
    [23:12:47] - Files status OK
    [23:12:47] - Expanded 46808 -> 252912 (decompressed 540.3 percent)
    [23:12:47] Called DecompressByteArray: compressed_data_size=46808 data_size=252912, decompressed_data_size=252912 diff=0
    [23:12:47] - Digital signature verified
    [23:12:47]
    [23:12:47] Project: 5766 (Run 0, Clone 317, Gen 1941)
    [23:12:47]
    [23:12:47] Assembly optimizations on if available.
    [23:12:47] Entering M.D.
    [23:12:53] Tpr hash work/wudata_00.tpr:  2687349694 1088418482 3355151513 3377246035 1324396062
    [23:12:53]
    [23:12:53] Calling fah_main args: 14 usage=100
    [23:12:53]
    [23:12:53] Working on Protein
    [23:12:54] Client config found, loading data.
    [23:12:54] Starting GUI Server
    [23:13:29] Completed 1%
    [23:14:04] Completed 2%
    [23:14:40] Completed 3%
    [23:15:16] Completed 4%
    [23:15:51] Completed 5%
    [23:16:26] Completed 6%
    [23:17:02] Completed 7%
    [23:17:37] Completed 8%
    [23:18:13] Completed 9%
    [23:18:48] Completed 10%
    [23:19:23] Completed 11%
    [23:19:59] Completed 12%
    [23:20:34] Completed 13%
    [23:21:10] Completed 14%
    [23:21:45] Completed 15%
    [23:22:21] Completed 16%
    [23:22:56] Completed 17%
    [23:23:32] Completed 18%
    [23:24:07] Completed 19%
    [23:24:43] Completed 20%
    [23:25:18] Completed 21%
    [23:25:54] Completed 22%
    [23:26:29] Completed 23%
    [23:27:04] Completed 24%
    [23:27:40] Completed 25%
    [23:28:15] Completed 26%
    [23:28:51] Completed 27%
    [23:29:26] Completed 28%
    [23:30:02] Completed 29%
    [23:30:37] Completed 30%
    [23:31:12] Completed 31%
    [23:31:48] Completed 32%
    [23:32:24] Completed 33%
    [23:32:59] Completed 34%
    [23:33:34] Completed 35%
    [23:34:10] Completed 36%
    [23:34:45] Completed 37%
    [23:35:21] Completed 38%
    [23:35:56] Completed 39%
    [23:36:32] Completed 40%
    [23:37:07] Completed 41%
    [23:37:43] Completed 42%
    [23:38:18] Completed 43%
    [23:38:53] Completed 44%
    [23:39:29] Completed 45%
    [23:40:04] Completed 46%
    [23:40:40] Completed 47%
    [23:41:15] Completed 48%
    [23:41:51] Completed 49%
    [23:42:26] Completed 50%
    [23:43:02] Completed 51%
    [23:43:37] Completed 52%
    [23:44:13] Completed 53%
    [23:44:48] Completed 54%
    [23:45:23] Completed 55%
    [23:45:59] Completed 56%
    [23:46:34] Completed 57%
    [23:47:10] Completed 58%
    [23:47:45] Completed 59%
    [23:48:20] Completed 60%
    [23:48:56] Completed 61%
    [23:49:32] Completed 62%
    [23:50:07] Completed 63%
    [23:50:43] Completed 64%
    [23:51:18] Completed 65%
    [23:51:54] Completed 66%
    [23:52:29] Completed 67%
    [23:53:04] Completed 68%
    [23:53:40] Completed 69%
    [23:54:15] Completed 70%
    [23:54:51] Completed 71%
    [23:55:26] Completed 72%
    [23:56:02] Completed 73%
    [23:56:37] Completed 74%
    [23:57:12] Completed 75%
    [23:57:48] Completed 76%
    [23:58:24] Completed 77%
    [23:58:59] Completed 78%
    [23:59:35] Completed 79%
    [00:00:10] Completed 80%
    [00:00:45] Completed 81%
    [00:01:21] Completed 82%
    [00:01:56] Completed 83%
    [00:02:32] Completed 84%
    [00:03:07] Completed 85%
    [00:03:42] Completed 86%
    [00:04:18] Completed 87%
    [00:04:53] Completed 88%
    [00:05:29] Completed 89%
    [00:06:04] Completed 90%
    [00:06:39] Completed 91%
    [00:07:15] Completed 92%
    [00:07:51] Completed 93%
    [00:08:26] Completed 94%
    [00:09:02] Completed 95%
    [00:09:37] Completed 96%
    [00:10:12] Completed 97%
    [00:10:48] Completed 98%
    [00:11:23] Completed 99%
    [00:11:59] Completed 100%
    [00:11:59] Successful run
    [00:11:59] DynamicWrapper: Finished Work Unit: sleep=10000
    [00:12:09] Reserved 75848 bytes for xtc file; Cosm status=0
    [00:12:09] Allocated 75848 bytes for xtc file
    [00:12:09] - Reading up to 75848 from "work/wudata_00.xtc": Read 75848
    [00:12:09] Read 75848 bytes from xtc file; available packet space=786354616
    [00:12:09] xtc file hash check passed.
    [00:12:09] Reserved 15168 15168 786354616 bytes for arc file=<work/wudata_00.trr> Cosm status=0
    [00:12:09] Allocated 15168 bytes for arc file
    [00:12:09] - Reading up to 15168 from "work/wudata_00.trr": Read 15168
    [00:12:09] Read 15168 bytes from arc file; available packet space=786339448
    [00:12:09] trr file hash check passed.
    [00:12:09] Allocated 560 bytes for edr file
    [00:12:09] Read bedfile
    [00:12:09] edr file hash check passed.
    [00:12:09] Allocated 10465 bytes for logfile
    [00:12:09] Read logfile
    [00:12:09] GuardedRun: success in DynamicWrapper
    [00:12:09] GuardedRun: done
    [00:12:09] Run: GuardedRun completed.
    [00:12:13] + Opened results file
    [00:12:13] - Writing 102553 bytes of core data to disk...
    [00:12:13] Done: 102041 -> 95475 (compressed to 93.5 percent)
    [00:12:13]   ... Done.
    [00:12:13] DeleteFrameFiles: successfully deleted file=work/wudata_00.ckp
    [00:12:13] Shutting down core
    [00:12:13]
    [00:12:13] Folding@home Core Shutdown: FINISHED_UNIT
    [00:12:15] CoreStatus = 64 (100)
    [00:12:15] Sending work to server
    [00:12:15] Project: 5766 (Run 0, Clone 317, Gen 1941)
    [00:12:15] - Read packet limit of 540015616... Set to 524286976.
    [00:12:15] + Attempting to send results [June 7 00:12:15 UTC]
    [00:12:17] + Results successfully sent
    [00:12:17] Thank you for your contribution to Folding@Home.
    [00:12:17] + Number of Units Completed: 310
    [00:12:21] Project: 10504 (Run 42, Clone 0, Gen 61)
    [00:12:21] - Read packet limit of 540015616... Set to 524286976.
    [00:12:21] + Attempting to send results [June 7 00:12:21 UTC]
    [00:12:23] - Couldn't send HTTP request to server
    [00:12:23] + Could not connect to Work Server (results)
    [00:12:23]     (171.67.108.21:8080)
    [00:12:23] + Retrying using alternative port
    [00:12:24] - Couldn't send HTTP request to server
    [00:12:24] + Could not connect to Work Server (results)
    [00:12:24]     (171.67.108.21:80)
    [00:12:24] - Error: Could not transmit unit 09 (completed June 6) to work server.
    [00:12:24] - Read packet limit of 540015616... Set to 524286976.
    [00:12:24] + Attempting to send results [June 7 00:12:24 UTC]
    [00:12:26] - Couldn't send HTTP request to server
    [00:12:26] + Could not connect to Work Server (results)
    [00:12:26]     (171.67.108.26:8080)
    [00:12:26] + Retrying using alternative port
    [00:12:27] - Couldn't send HTTP request to server
    [00:12:27] + Could not connect to Work Server (results)
    [00:12:27]     (171.67.108.26:80)
    [00:12:27]   Could not transmit unit 09 to Collection server; keeping in queue.
    [00:12:27] - Preparing to get new work unit...
    [00:12:27] + Attempting to get work packet
    [00:12:27] - Connecting to assignment server
    [00:12:28] - Successful: assigned to (171.67.108.11).
    [00:12:28] + News From Folding@Home: Welcome to Folding@Home
    [00:12:29] Loaded queue successfully.
    [00:12:30] Project: 10504 (Run 42, Clone 0, Gen 61)
    [00:12:30] - Read packet limit of 540015616... Set to 524286976.
    [00:12:30] + Attempting to send results [June 7 00:12:30 UTC]
    [00:12:32] - Couldn't send HTTP request to server
    [00:12:32] + Could not connect to Work Server (results)
    [00:12:32]     (171.67.108.21:8080)
    [00:12:32] + Retrying using alternative port
    [00:12:33] - Couldn't send HTTP request to server
    [00:12:33] + Could not connect to Work Server (results)
    [00:12:33]     (171.67.108.21:80)
    [00:12:33] - Error: Could not transmit unit 09 (completed June 6) to work server.
    [00:12:33] - Read packet limit of 540015616... Set to 524286976.
    [00:12:33] + Attempting to send results [June 7 00:12:33 UTC]
    [00:12:35] - Couldn't send HTTP request to server
    [00:12:35] + Could not connect to Work Server (results)
    [00:12:35]     (171.67.108.26:8080)
    [00:12:35] + Retrying using alternative port
    [00:12:36] - Couldn't send HTTP request to server
    [00:12:36] + Could not connect to Work Server (results)
    [00:12:36]     (171.67.108.26:80)
    [00:12:36]   Could not transmit unit 09 to Collection server; keeping in queue.
    [00:12:36] + Closed connections
    [00:12:36]
    [00:12:36] + Processing work unit
    [00:12:36] Core required: FahCore_11.exe
    [00:12:36] Core found.
    [00:12:36] Working on queue slot 01 [June 7 00:12:36 UTC]
    [00:12:36] + Working ...
    [00:12:37]
    [00:12:37] *------------------------------*
    [00:12:37] Folding@Home GPU Core
    [00:12:37] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
    [00:12:37]
    [00:12:37] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
    [00:12:37] Build host: amoeba
    [00:12:37] Board Type: Nvidia
    [00:12:37] Core      :
    [00:12:37] Preparing to commence simulation
    [00:12:37] - Looking at optimizations...
    [00:12:37] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
    [00:12:37] - Created dyn
    [00:12:37] - Files status OK
    [00:12:37] - Expanded 46731 -> 252912 (decompressed 541.2 percent)
    [00:12:37] Called DecompressByteArray: compressed_data_size=46731 data_size=252912, decompressed_data_size=252912 diff=0
    [00:12:37] - Digital signature verified
    [00:12:37]
    [00:12:37] Project: 5768 (Run 5, Clone 247, Gen 693)
    [00:12:37]
    [00:12:37] Assembly optimizations on if available.
    [00:12:37] Entering M.D.
    [00:12:43] Tpr hash work/wudata_01.tpr:  3006982188 1109567933 3998706587 2590760071 1192210293
    [00:12:43]
    [00:12:43] Calling fah_main args: 14 usage=100
    [00:12:43]
    [00:12:43] Working on Protein
    [00:12:44] Run: exception thrown during GuardedRun
    [00:12:44] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
    [00:12:44] Going to send back what have done -- stepsTotalG=0
    [00:12:44] Work fraction=0.0000 steps=0.
    [00:12:48] logfile size=9585 infoLength=9585 edr=0 trr=23
    [00:12:48] + Opened results file
    [00:12:48] - Writing 10121 bytes of core data to disk...
    [00:12:48] Done: 9609 -> 3588 (compressed to 37.3 percent)
    [00:12:48]   ... Done.
    [00:12:48] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
    [00:12:48]
    [00:12:48] Folding@home Core Shutdown: UNSTABLE_MACHINE
    [03:20:45] Project: 10504 (Run 42, Clone 0, Gen 61)
    [03:20:45] - Read packet limit of 540015616... Set to 524286976.
    [03:20:45] + Attempting to send results [June 7 03:20:45 UTC]
    [03:20:46] - Couldn't send HTTP request to server
    [03:20:46] + Could not connect to Work Server (results)
    [03:20:46]     (171.67.108.21:8080)
    [03:20:46] + Retrying using alternative port
    [03:20:48] - Couldn't send HTTP request to server
    [03:20:48] + Could not connect to Work Server (results)
    [03:20:48]     (171.67.108.21:80)
    [03:20:48] - Error: Could not transmit unit 09 (completed June 6) to work server.
    [03:20:48] - Read packet limit of 540015616... Set to 524286976.
    [03:20:48] + Attempting to send results [June 7 03:20:48 UTC]
    [03:20:49] - Couldn't send HTTP request to server
    [03:20:49] + Could not connect to Work Server (results)
    [03:20:49]     (171.67.108.26:8080)
    [03:20:49] + Retrying using alternative port
    [03:20:51] - Couldn't send HTTP request to server
    [03:20:51] + Could not connect to Work Server (results)
    [03:20:51]     (171.67.108.26:80)
    [03:20:51]   Could not transmit unit 09 to Collection server; keeping in queue.
    [03:20:51] + Working...
    It's a water cooled GTX 295 processing.
    As you can see, it gets all the way through the work, but then can't upload it. Curiously the other half of the card is working fine. I've even dialled back the overclocks from 666 to 648 on the core to see if it was a stability issue... No difference.
    The start up shortcut reads:
    "C:\Program Files (x86)\Folding@home\Folding@home-gpu\fah6.exe" -gpu 1 -forcegpu nvidia_g80
    Any clues, or is this server side? It's been happening for a week now - well I've noticed it since the chimp challenge.
  2. Eldorado
    Eldorado Needs new glasses..
    12 Mar 2012
    Not an answer, but I am getting similar problems: I get failed units that deliver ppd, and completed units that don't. (They upload successfully, and give me the estimated points),
    I'm sure we are both looking for answers on this one.
    Though, I assume it's server side issue.
  3. Tattysnuc
    19 Jul 2009
    Weirdest thing is that it's only happening for the second core of my GTX 295. The first one is working fine.....
    Anyone? Any ideas?
  4. Tattysnuc
    19 Jul 2009
    I un-installed everything, then re-installed it all, then spotted that the shortcut I'd got for the second core on my GTX 295 didn't have the operator -forcegpu nvidia_g80 set, so I've added it back in and everything seems to be working fine now for a couple of days. Back up to 15k per day @684core/1156mem....
  5. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
    glad you sorted it Tatty :thumb:
  6. Tattysnuc
    19 Jul 2009
    It sees to be working better than ever the past couple of days. I used to have it set @ 666/1156 but I'd inadvertently set the clocks to 684/1156 (ie +18mhz faster) and it's been fine now for two days.
    Is it possible that the reason that my card overclocks better (albeit a pittance more) could be because my CPU is now on stock??? I doubt that it's a power issue as the PSU is a 750W Be Quiet DarkPower which should be well plenty big enough!!
    I must update my backup of the icons from my desktop when I get home so that I don't use shortcuts that do not have the -forecegpu etc set...
