First Sli test, just to make sure it's at least displaying okay. I'm not sure of the oc though - I don't know if MSI Afterburner is oc'ing both cards using the same settings.
FPS: 50.0 Score: 2092 Min FPS: 27.7 Max FPS: 98.6 Render: Direct3D11 Mode: 1920x1080 8xAA fullscreen Preset Extreme HD Platform: Windows 7 (build 7601, Service Pack 1) 64bit CPU model: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (3300MHz) x4 GPU model: NVIDIA GeForce GTX 680 9.18.13.2000 (2047MB) x1
here is my system FPS 82.4 SCORE 3447 Min FPS 21.4 Max FPS 135.3 System Windows 7 (build 7601, service pack 1) 64 bit CPU Model AMD FX 6300 @4.6Ghz GPU Nvidia GEFORCE GTX 560Ti 9.18.13.1422 (1279)x2 RENDER Direct 3D11 Mode 1920x1080 full screen Preset custom Quality High
A little while back I was trying to get up the tables on another forum for the highest score on a single card. I got the following score which ran perfectly but sadly the overclock won't hold up for the likes of BF3.
Little bit of thread resurrection.. Tested out my A10-7850K, quite quietly cooled. Only things I've touched in the bios is set the ram to use it's XMP profile, so that's running very sweetly at 1866. I've also upped the GPU to 1Ghz. I've still to install some 2400 ram and see how far the gpu will oc. The score was around half the above running at 1920x1080 (746 iirc). Not too bad really.
