Overclocking Unstable overclock
Discussion in 'Tech Support' started by ubiquity, 4 Sep 2010.
  1. ubiquity
    ubiquity What's a Dremel?
    27 Aug 2010
    Hi, I recently ordered a overclock bundle from scan. Its the i5 760, running at a guaranteed 4Ghz overclock rather than the standard 2.8.
    Windows 7 64bit bluescreened on the install screen, and now regularly blue screens at random intervals. I am going to contact scan and see what they say, I believe they did not test the stability of the overclock before shipping it of to me, but was wondering if there are any checks I can do myself to make sure it is not another problem.
    Is there any good stability testing software, any suggestions would be welcome at this point!
    Thanks,
    Rich
  2. sakzzz
    sakzzz Minimodder
    13 May 2009
    You could clear the CMOS and reset the overclock, but then you would have to manually overclock it again.
    OR
    contact SCAN and see their take on it....
  3. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    I'd retim everything on the mb and cpu then use bindi's nice guide as a reference goal http://www.bit-tech.net/hardware/cpus/2009/09/21/overclocking-intel-s-core-i5-750/1
    but since it's prebuilt.. I'd send it back in and have them pay for shipping- explain the problem
    sounds like a ripoff really.. you can do it yourself, save money.. I wouldn't do their work for them though- you paid the extra have them do the testing
  4. ubiquity
    27 Aug 2010
    The thing is I cant even touch the bios settings or I invalidate the warranty! They were nice enough to build it into the case and include the psu I bought, but I don't think they had enough time (it was a bank holiday after all) to properly test the overclock!
    The whole reason I paid the extra £40 was so that I was guaranteed a stable overclock, and not left to gamble on how much milage I could get out of the i5 760. Also all the features to get it running just so totally bamboozle me in all honesty!
    Have e-mailed them and put the same initial post on the scan section of this forum, lets see what happens....
    Thanks for the advice :)
  5. bulldogjeff
    2 Mar 2010
    I'd say it's all got to go back in the box and back to scan.
    Teelzebub likes this.
  6. PocketDemon
    PocketDemon What's a Dremel?
    3 Jul 2010
    Just make sure you explicitly ask Scan to choose a courier for returning things otherwise you may end up either out of pocket or in a hell of a fight to get the money back (& banned from using them again).
  7. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    I would send it back, if you start playing with the settings then they might not take it.
    As proven by the Scan dream pc wins they do know what their doing, but i'm skeptical that you can say an overclock is 100% stable and retail it as such.
    I've heard of factory overclocked gpu's artifacting and having to be turned down.
  8. TheBlackSwordsMan
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
    Did they really fully test every OC they do ? Ive serious doubt about that
    We put a Vcore, a FSB, it boot ? Box the thing
  9. ubiquity
    27 Aug 2010
    I think I will send it back, just need for them to respond to my e-mails!
  10. Guest-56605
    Guest-56605 Guest
    No you'll have to run the gauntlet of their Returns Department staff on the phone, recent experience has proven they can be shall we say confrontational/well it worked perfectly when it left us type of attitude and stipulate you want a courier to collect from you...
    bulldogjeff likes this.
  11. Teelzebub
    27 Nov 2009
    I never had problems RMA'ing goods with Scan it's just their testing methodology I've had issue with in the past.
    Guest-56605 likes this.
  12. Guest-56605
    Guest-56605 Guest
    There's most certainly that to...
  13. AstralWanderer
    AstralWanderer What's a Dremel?
    17 Apr 2009
    In light of the above comments on testing returns, taking some photos of the system blue-screening may be a good idea...
  14. ubiquity
    27 Aug 2010
    Thats a very good idea, I will keep my iphone ready to snap as soon as blue screen appears!
