Graphics Upgrade Choices from GTX550 TI
Discussion in 'Hardware' started by lcdguy, 4 Jan 2014.
  1. lcdguy
    lcdguy Minimodder
    25 May 2004
    I have been out of the pc hardware loop for a while and was wondering if upgrading from a Nvidia GTX550 TI to a 770 series card would be beneficial. Or are there other considerations. My budget is around $400 Canadian.
  2. narwen
    narwen narwen
    6 Aug 2010
    It should double your fps in most games
  3. lcdguy
    lcdguy Minimodder
    25 May 2004
    even i want to run the res at 2560x1440
  4. NIHILO
    NIHILO The Customer isn't always right!
    30 Dec 2013
    i did a similar upgrade that you plan on doing. i had the GTX560ti and upgraded to the GTX760 and i was not disapointed(60FPS in BF4, Ultra settings 1650x1080). so you should be similarly or more pleased than i was with the 770
  5. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    For 1440p I would strongly urge you to make sure you get 4GB vram card. I settled on 2GB 670 when I got my 1440p and already finding myself having to scale things back in some titles.
  6. lcdguy
    lcdguy Minimodder
    25 May 2004
    I would like to report back that i have upgraded and what a difference :).
    ended up with the following.
    E-VGA Geforce GTX 760 SC 4GB it was around $329 CDN which i thought was a great price considering it's a 4GB card.
    thanks for the help everyone.
