CPU Upgrade CPU worth it.
Discussion in 'Hardware' started by wolf5ster, 13 Apr 2019.
  1. wolf5ster
    wolf5ster Minimodder
    2 May 2011
    Evening all,
    Worth upgrading from Ryzen R5 1600 to the R5 2600. I am mainly using it now for gaming and not much else at 1080p, and slowly importing my record collection using a Digitnow conversion turntable to my pc.
    Games playing at the moment are Metro Exodus and Battlefield V. The system seems ok at the moment but still using the stock cooler, although I do have a Coolermaster 212 evo in the loft without AM4 doings.
    The motherboard I am using at the moment is a MSI B350M mortar with updated BIOS and all fitted in a smaller Corsair spec blue 3 case.
    :thumb:
  2. TheMadDutchDude
    23 Aug 2013
    Nope. Wait for the next gen chips in a couple of months.
  3. Vault-Tec
    30 Aug 2015
    Wot 'e sed.
    wolf5ster likes this.
  4. Colonel Sanders
    Colonel Sanders Minimodder
    25 Jun 2002
    I will agree waiting until Zen 2 or Ryzen 3000 comes out, I have read s lot of posts on SA claiming Ryzen 2000 CPUs are kind of in a fire sale right now. I would still consider holding out for Zen 2, but if your budget is limited and you absolutely need to upgrade right now then I believe you can find a good deal on a 2000 series CPU. I still would not recommend upgrading to Ryzen 2000 but you can waste invest your money however you want.
  5. adidan
    25 Mar 2009
    I'd definitely wait a couple of weeks, AMD are meeting partners on the 23rd (iirc) about Zen2 and Navi.
    There are rumours something may happen on May 1st to coincide with AMD's 50th anniversary - a release? Probably just more clarity than anything.
    Interestingly though an AGESA version has been getting released by several manufacturers for Ryzen 'Matisse', it smells like something's gearing up.
    Don't get me wrong, the 2600 is a great chip but whether you'd see any difference between it and your 1600 for 1080p gaming, not sure you would TBH - it may be worth checking some benchies.
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    The 1 - 3 fps gain ain't worth it, better off waiting for next gen.
  7. spolsh
    spolsh Multimodder
    4 Feb 2012
    techspot's just done a Ryzen 1700 to 2600X comparison, and the 2600X does come out on top for gaming on that, but not enough of a difference to shout about. Figure it'll be pretty similar with the 1600, so not really worth while as an upgrade.
  8. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Aye, although I'd imagine that even if the next gen Ryzens are considerably better than the current ones, the FPS difference will still be negligible, or at very best disproportionate to the upgrade cost. No harm in waiting and seeing, though, but it doesn't feel like a CPU upgrade will be the best use of cash.
    Omnislip likes this.
  9. Vault-Tec
    30 Aug 2015
    With higher core loads in games now the ghz gap is starting to close somewhat. It'll probably matter at 1080p but anything above that will care far more about your GPU.
    It's quite funny how you need the most expensive CPUs to play games on cheaper GPUs. These people would be better off spending more on a GPU and monitor, then just using a cheap CPU. Mind you, haven't we been saying that for over a decade?
    adidan likes this.
  10. adidan
    25 Mar 2009
    Pretty much why my 3770 has managed ok - bumping up to 1440p and a 1080 helped more than a cpu.
    Mind you it is time now.
  11. Vault-Tec
    30 Aug 2015
    I benched The Division 2 at my display's native 1080p on my Vega 64. Ultra detail. Max FPS was 150 or so. Very impressive, but the mins were low 30s and even Freesync could not save it. Bumped up to 1440p using VSR and the max was around 70. Not as impressive , but mins were 46.
    That's probably something to do with my 2.4ghz 10 core CPU, but obviously it's the res I chose to game at. And the bonus? It looks ten times better to boot.
    That's the one major draw to being sat down at eye level with my 65" TV from 12ft away. 1080p now looks like butthole and less? Yeah, let's not go into that.
    Thankfully 1080p just about cuts it or I'd be shopping for a new one. It does run 4k, but only like 'day one' 4k so nothing is compatible with it like say my Xbox One X. I do have a BR player that may work with it, but nothing else likes it.
  12. wolf5ster
    2 May 2011
  13. TheMadDutchDude
    23 Aug 2013
  14. Anfield
    Anfield Multimodder
    15 Jan 2010
  15. TheMadDutchDude
    23 Aug 2013
    Didn’t know they had those there!
    My buddy actually picked one of those up for his new build a few months ago. The red trim is actually surprisingly nice.
  16. wolf5ster
    2 May 2011
    All nice options
  17. wolf5ster
    2 May 2011
  18. wolf5ster
    2 May 2011
    Finally got one, monitor that is
    https://www.pcworld.co.uk/gbuk/comp...ed-led-gaming-monitor-black-10187614-pdt.html
    Finally got one today, just finding my way around it.:):thumb:
    adidan likes this.
