CPU Upgrade from Phenom X3 8650
Discussion in 'Hardware' started by Auxilliary, 26 Dec 2011.
  1. Auxilliary
    Auxilliary Crashes into space stations
    27 Jan 2011
    So as you can see in my sig, I have a Phenom X3 8650 and well its starting to strugle rather alot.
    I have decided to upgrade with the koney i have gained from christmas and some of my jobseekers :(
    I need to get:
    CPU
    Motherboard
    RAM
    the graphics card will be updated at a later date as its not doing too bad, just runs a little hot is all.
    My max budget is £330 but obviously I'd like to spend less, what would you guys/girls reccomend to buy?
  2. AoE
    AoE What's a Dremel?
    4 Oct 2011
    YGPM
  3. Auxilliary
    27 Jan 2011
    Hey there, im not sure yet I'd like to get some other options together aswell, but ill contact you if i decide to stick with AMD
  4. AoE
    4 Oct 2011
    No problem, for price/performance AMD cant be beaten IMO, intel although I would love to go that route is an expensive one, plus if you do stick AMD, go phenom II X3, unlock extra core and overclocking is made easy with the UEFI BIOS on my Asus motherboard.
  5. Auxilliary
    27 Jan 2011
    Out of interest is that CPU you have the 960T? as i could go for that as i see you have a decent OC on it + unlocked it to a six core
  6. AoE
    4 Oct 2011
    Yea it is, very easy chip to overclock and unlock cores from, the only reason I bought it.
  7. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    £160 for 2500k
    £100 for motherboard
    £40 for 8GB of RAM
    Otherwise pick up a phenom quad 9XX cores. About £60 would be a fair price. And possibly upgrade your RAM while you at it.
  8. AoE
    4 Oct 2011
    For £89 new you can get a 960t, I got mine unlocked to x6 and increased to 3.8Ghz on stock vcore, in cinebench it owns an i7 960 which is a £200 chip lol, performs unreal on games, plays crysis for example on high with no problems.
  9. The Protocol
    The Protocol What's a Dremel?
    6 Sep 2011
    960T, Phantek dual tower heatsink in whatever colour you want, Crosshair IV and 8GBs of Ripjaws 1600Mhz and off you go
  10. legoman
    legoman breaker of things
    28 Feb 2010
    AoE, dont be afraid to dream a little bigger ;)
    960T is a beaut of a chip i wouldnt give bulldozer a look at the moment after WindWithMe's review http://forums.bit-tech.net/showthread.php?t=223083
    id say get an AM3+ capable board so you have an upgrade path though the black CPU socket denotes AM3+ capable on boards so its a nice giveaway. Ram im happy to admit i have no idea i lost all concept of the stuff after the original DDR days!
  11. AoE
    4 Oct 2011
    I know I offered the OP, my brand new asus M5A99X EVO AM3+ board and 2GB DDR3 1333 Ram for £75inc special del, plus a gtx 550 ti only three months old all in for £145inc.
  12. Tangster
    23 May 2009
    These new phenoms overclock a darn slight better than my old 1050T hexcore. Still, I'd go 1155 for the upgrade path to ivy bridge(unless AMD's next generation of bulldozer actually works as advertised)
  13. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    Absolutely don't go with the Bulldozer chips, they're pathetic. Even the flagship 8150 won't beat an i5 2500k for gaming or everyday computing. Speaking of the i5 2500k, that's my recommendation, that with a Z86 motherboard so you can upgrade to ivy bridge later.
  14. law99
    law99 Custom User Title
    24 Sep 2009
    The 2500k is stupid cheap for what you get. ESP. When overclocking is thrown in the mix. Xxx
  15. Auxilliary
    27 Jan 2011
    Decided im going to get:
    Intel i5 2500K
    Asus Maximus IV GENE-Z/GEN3
    8GB Vengance LP Ram.
    Just one question, is it possible to get the Vengance LP Ram in Red?
  16. Tangster
    23 May 2009
    Yes!
  17. Auxilliary
    27 Jan 2011
    thanks man, just a shame its getting close to being double the price of the same but in black :(
  18. mucgoo
    mucgoo Minimodder
    9 Dec 2010
  19. Auxilliary
    27 Jan 2011
    thanks for the suggestion but if I was to choose another motherboard it would have to be M-ATX as im going to be putting it in a FT-03, and preferably not gigabyte as my current board is a gigabyte and its given me no end of hassle.
    Plus i'd like to get a board that supports Ivy Bridge (when it arrives)
  20. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    Fair enough. You'd only save about £30 rather than £60 by getting an cheaper MATX board and I'm guessing you want the red styling of the ASUS?
    All 1155 socket motherboards will support ivy bridge so that's not a worry.
