Build Advice Upgrading my graphics card.
Discussion in 'Hardware' started by russ555, 7 Feb 2011.
  1. russ555
    russ555 What's a Dremel?
    24 Apr 2009
    I ran out of patience, they are both on their way :D
  2. Sketchee
    Sketchee Suddenly, looters! Hundreds of 'em!
    23 Oct 2010
    Good for you :)
    What did you get exactly in the end? link!
  3. russ555
    24 Apr 2009
    The PSU
    The GTX 560
    Should be here on friday. In the mean time I want to test my current card so I have something to compare the new one to. Any suggestions on demanding games? So far I have thought of crysis and farcry 2.
  4. russ555
    24 Apr 2009
    Im thinking about overclocking my CPU but according to the guides I can't raise the FSB much higher than my ram supports, without stability issues or altering other things and Im trying to keep it simple for the moment at least.
    The problem is Im using 2 different kinds of ram. The 2 1GB sticks that came with my PC and the 2 2GB ocz pc2 8500 platinums I added a year or so ago. I looked at the sticker on the side of the sticks and the older ones say 667 which seems to be the ram speed. The OCZ ram on the other hand didn't have anything that was obviously the speed so I googled it and found from the OCZ website that they are 1066 :(.
    I thought I should seek some expert advice before continuing.
    What would you suggest I do? remove the older ram and just go with 4GB? mess with the other settings like the FSB:ram ratio? or quit while Im ahead?
  5. Deders
    Deders Modder
    14 Nov 2010
    yeah, 4GB is plenty for gaming, does your ram work in dual channel with uneven ram sticks?
  6. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    Hey Russ, I've just upgraded from a 8800GT to a 560, and I'm sure you'll be as delighted as me with yours. I also have a 650W power supply, which fortunately has two 6/8pin GPU cables. Hooking it all up really is as straightforward as can be, though you'll need to remove an extra blanking plate from the rear of your case since the GPU is a dual slot design.
    My advice would be to download the latest drivers from nVidia now. When your new card and PSU are installed your machine will boot as normal but your display resolution will probably be borked. At this point run your new driver (don't bother with the installation disc that'll come with your card) and it'll take care of everything. You may want to select the "clean install" option to remove all traces of your 8800 driver.
    You may then find that your audio is coming from your monitor via HDMI/DVI, in which case go into the Windows control panel and choose your soundcard as the default audio device.
    Then, simply enjoy all your games, videos, pornography or whatever! :)
    Let us know how it goes.
    Cleggy.
  7. russ555
    24 Apr 2009
    Erm don't really know CPU Z says dual but I don't know if that means its running in dual or if it is just capable of doing so.
    How do I check?
  8. Deders
    Deders Modder
    14 Nov 2010
    Would normally say in the post screen before windows boots, but if CPUz says so then i'm 90% confident that it is, good to know that.
  9. russ555
    24 Apr 2009
    Thanks for the tip about the plate and the drivers.
  10. russ555
    24 Apr 2009
    Its seems that while removing the ram I killed 3 LEDs in the side fan :(
    Also I overclocked my fsb from 340 straight to 400 and when I started orthos CPU test the temp went from around 40 to 60 in about 2 seconds but then it seemed to stay there for about a minute before I chickened out, stopped the test and dropped it down to 350.
  11. civicteer
    civicteer What's a Dremel?
    26 Apr 2010
    Hi Sorry to hijack a thread but its a simple question, I was going to get this card and the Nvidia website says min PSU is 500w NOT 600W? I have a Corsair VX550,will I have to change it?
    Thanks
    Px
  12. Cleggmeister
    12 Oct 2009
    You'll be fine unless you're running a really heavy rig with lots of HDDs, expansion cards, a massive OC, etc.
  13. Deders
    Deders Modder
    14 Nov 2010
    The figure on the website has to acount for a PSU's with varying quality, a good one like yours wil have no problems, especially as it has one large 12v rail.
  14. civicteer
    26 Apr 2010
    thanks for the replies :) :D
  15. russ555
    24 Apr 2009
    Quick question. There is some sort of connector on the end of a cable that has got the 3 moxlex connections on it. Is it important? and where does it go?
    EDIT: abit more info, it's quite thin and it looks like there is 4 slots for pins to go into.
  16. russ555
    24 Apr 2009
    I tried it without that other connector and it is working fine and I can now play crysis warhead on max settings :D. I've never been so happy to see shadows :p.
    So a big thanks to all that have helped.:clap::rock:
