USB 2.0 missing
Discussion in 'Hardware' started by Pookeyhead, 25 Sep 2005.
  1. Pookeyhead
    30 Jan 2004
    Anyone know why my DFI NF4 reports itself as having no high speed USB ports, when it patently has? I'm assuming the NForce chipset drivers that come with it should have installed USB 2.0 drivers.
  2. chemo
    chemo True Jungle Brother
    20 Feb 2005
    dont you need sp1/sp2 for usb2?
  3. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    SP1 I believe :)
  4. hitman012
    hitman012 Minimodder
    6 May 2005
    The drivers that ship with some of the DFI nF4 boards are very flaky... try replacing them with the XP generic ones.
    Go to the Device Manager, then right click USB Hub (or USB Root Hub), and click Properties. Go to the driver tab, then click Uninstall. Do that for each of the instances of that driver.
    Reboot, and XP should redetect your ports as shiny new USB 2.0 ones :)
    Also, unless you're running RAID, remove the nVidia IDE drivers and firewall as well as nTune. All those things seem to cause a lot of problems with DFI nF4s.
  5. Pookeyhead
    30 Jan 2004
    I'm using Win XP Pro with SP2. It's a new, legal copy, so I never did the upgrade to SP1, then SP2 thing, but I'm assuming it would have everything I need. It seems to new, that when I log into Windows update, it finds nothing.
    I'll try replacing them with generic Win XP ones, and see what that does.
    Thing is... USB 2 appears in device manager, it's just when I plug in a USB 2 device, it warns me that it would be better in a USB 2 port, and tells me I have none in this machine.... :wallbash:
  6. Guest-2867
    Guest-2867 Guest
    Thats really odd, I had that problem with a USB2.0 hdd caddy once, it turned out to be the caddy at fault as every other usb2 peripheral worked fine, are you using an external (powered or none powered) hub?
    Does every USB peripheral pop up the same error?
  7. thecrownles
    thecrownles What's a Relix?
    27 Feb 2004
    My guess would be going to the mobo or chipset (AMD or intel?) website and getting the latest drivers. I have a ASUS P4C800 E and it doesn't detect the USB drives even with all the latest updates on XP, unless you go and install Intel's 875P driver. Try finding the same for your mobo.
  8. Adnuo
    Adnuo Banned
    28 Aug 2005
    As said, grab the latest NForce drivers off nVidia. USB2.0 is always touchy with XP, in my eXPerience (LOLOL >_<). Also make sure it's enabled in BIOS :)
  9. Pookeyhead
    30 Jan 2004
    Im using no external hub... just noticed this when I plugged my camera into my PC.... tried every USB socket and was told the same thing. Also tried my external drive, and that's the same.
  10. blknoel
    blknoel What's a Dremel?
    14 Jun 2004
    Uninstall the driver of any USB 2.0 hub that is already there (via Device Manager) . Then go to C:\Windows\drivers to delete the USB 2 driver folder that u once installed from the DFI driver CD.
    Reboot, Windows will automatically install new driver for your USB hub, now its USb 2.0 for you, given you set [USB 1.1 + 2.0] in the Bios :)
