Networks USB 802.11g adaptor?
Discussion in 'Hardware' started by hcker2000, 4 Jun 2005.
  1. hcker2000
    hcker2000 What's a Dremel?
    21 Oct 2004
    I have been working on my car pc for a long while now and I think I would like to get rid of the pci 802.11g card. I would like to replace it with a usb 802.11g adaptor that is about the same size as a pen drive. This will save me alot of space and I will be able to make the pc easy to take in and out of the glove box for use in the house or where ever.
    What I need to know is what ones work with netstumbler .4 in win2k?
    I asked on there forums but they were just like "none of them are officaly suported" thread closed :waah:
    I would prefer it to be as cheap as posible but it has to work with netstumbler. Also I prefer to grab things from newegg but am not apposed to some place else just link over to it if you have an adaptor that works with netstumbler.
  2. eclipse
    eclipse Guest
    i used net stumbler and all i could figure out what to do with it was FOR IT TO MAKE NOISE. i use winc i found it on download.com i think it its 100x better and it supports almost all adapters try it out
  3. hcker2000
    21 Oct 2004
    I checked it out looks nice but would be better if it was free. Although that isnt a major hurdle.
    It would just be nice if netstumbler suported some more usb stuff.
  4. djtitan
    djtitan What's a Dremel?
    18 Aug 2004
    If my memory serves me correctly, the older gen linksys Wusb54gp ones run off a chipset that is compatible with netstumbler (I think they were the prism2, but im not quite sure), but I think you also need a different version of the usb driver. I am going to hunt around as to where I saw that driver, and PM you if I find it. Otherwise, good luck
  5. hcker2000
    21 Oct 2004
    That adapter I do beleave is reported to work with netstumbler. It is a littly on the pricy side. I thought about buying a $20 adapter from newagg and just hoping it works but I havn't decided for sure yet.
