ok so i just got my new Digi Cam, Canon A40, its great, but now i want to connect it to my camputer to rip the images... i cant get that to work tho... i dunno what to do , i have loaded all the drivers and i spent all night last night on it, it connects via the usb port and then it has a small usb output... i tried it on both ports and on the extra add-in ones also (the ones in the pci slot covers) still nothing, i also tried to use a usb mouse for a while when my camputer was brand new(last saturday) but that didnt work so i was like 'screw it i gotta play CS' so i dunno if usb can just die? my motherboard works perfectly fine... what do you think?
u tried the mouse or the digicam on another pc with a usb connection?? try that first... ...also welcome to the forums dude...
what motherboard have you got as on my MSI board when you enable high performance defaults the usb ports are disabled in the bios. If you are using the same bios as me then go into it and look under intergrated peripherals and there should be an option called usb ports. You should enable them all and then enable yhe setting below them. You do not need to enable the 64 bit emulation.
I just plugged in a new USB mouse tonight and couldnt get it to work , guess what it was disabled in the BIOS , once i clicked on it took 2 minutes to get it up and running.
i have anoptical mouse and the light didnt come on so i didnt think that it worked i think that im gonna rma it
Optical , so was mine and it didnt light up either untill i enabled it in the BIOS ,just give it a try PLEASE
what is rma it means? oh yeah i rember the usb thing in da bios....could be either set to bios or system....if im not mistaken
oh no wonder....it sound so familar...cuz you know lazy... rma for my deathstar ops sorry lazy to remind you bout it
i did try it in my bois 3 times, but just for you, i will do it another 3 times and double click the mouse
