Electronics USB Hub?
Discussion in 'Modding' started by Jpantoga, 22 Apr 2005.
  1. Jpantoga
    Jpantoga What's a Dremel?
    12 Jan 2004
    I am interested in building a USB hub for my computer that will hopefully add about 4 USB connections to my computer. I want to build it in an altoids tin, and plan on wiring it myself, but I don't know how to make it safe. Do I just wire it Pin-for-pin to each connector? Do I need something to distribute the voltage evenly to each USB connector? Does it need it's own power supply? If you have any experience building one of these, or can direct me to someone who can, help would be much appreciated.
    Jpantoga
  2. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    You need a chip specifically designed to act as a USB hub. You can't simply wire the data lines together. That'd be bad.
  3. Springs
    Springs Boing boing
    29 Aug 2004
    best thing to do is just buy one and mod it... they aint that expensive these days..
