News USB-IF courts controversy with USB 3.2 naming plan
Discussion in 'Article Discussion' started by bit-tech, 1 Mar 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Ummm..
    Also, USB naming convention throws me for a loop every time I have to explain it. Or think about it. Type A, C, Z, Jabberwocky.. Kopf ist kaputt.
  3. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  4. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Just when you think they couldn't make more of a mess of their naming conventions... Oh dear me.
  5. Gareth Halfacree
    4 Dec 2007
    SEE? SEE HOW CONFUSING IT ALREADY IS?!?!?!
    (I'll go fix that, ta!)
    EDIT:
    Oh, somebody beat me to it - thanks, kind stranger!
    liratheal and Dogbert666 like this.
  6. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Maybe they have an aversion to the numbers 4 & 5.
  7. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    "USB 3.0 USB 3.1 Gen 1 and USB 3.2 Gen 1 are the same thing!" is a popular meme, but not actually true beyond data transfer rate.
    The reason for USB 3.2 subsuming 'older' standards to to keep all the parts of the USB protocol other than data transfer speed up to date and in lock-step. After all, you want to be able to connect both high-bandwidth storage arrays and low-bandwidth wireless mouse dongles to the same port. Without keeping all bandwidth levels on the same standard, you end up with either:
    - New devices released on older standards, so all host devices need to be able to deal with decades of legacy standards and switch between therm depending on device attached (an obvious headache with hubs and chaining involved). See the *********** of USB PD that happened when "oh, but legacy devices want to do X, Y or sometimes Z! (even though Y and Z are wildly out of spec)" gets kowtowed to.
    - Low-bandwidth devices need to support the full 20gb/s transfer rate even when it is massive overkill and a huge cost inflation
    - A new standard that incorporates multiple bandwidth levels within the same standard.
    Option 3 is the one the USB IF have gone for, and the one they should have gone for for USB PD in the first place.
  8. Assassin8or
    Assassin8or Minimodder
    24 Apr 2009
    You have to do this anyway and manufacturers are always going to use old well known, easily accessible, cheap to implement USB specs if they don't need anything better. So USB 2.0 is probably going to be around for many years(decades?) more due to mice not needing anything else.
    Also new client devices need to connect to old hosts in a compatible manner(my server at home has on board USB 2.0 throughout, my USB 3 thumb drives have to cope with that.)
    I don't get this, surely to cost of the controller is the major factor in implementing any standard?
    This is what I don't get surely part of the speed limits is the quality of the cable used and the electronics in the controller probably already have to check for this right? (or do they just dumbly decide on what the highest standard is that each device supports and then tries to use my 2.0 Type-B to A like a 3.0 cable?
  9. edzieba
    14 Jan 2009
    That's the point of having multiple bandwidths in the same standard: you can implement a cheap USB 3.2 controller that only needs to hand off a few kilobytes now and again, or a beefy USB 3.2 controller that can shunt tens of gigabits about. If you relegate lower bandwidth devices to "just use USB 2.0" you're now designing for a nearly two decade old standard and don't get the benefit of later developments (e.g. Type C).
  10. RedFlames
    23 Apr 2009
    So you'll have USB 3.0, USB 3.1 Gen 1 and USB 3.2 Gen 1 all referring to the same speed/standard depending on the age of the device...
    And then you have 'is this Type-C or Type C with Power Delivery?'
    And no doubt in a couple years time we'll have USB π Gen 3⅞
  11. jb0
    jb0 Minimodder
    8 Apr 2012
    Super USB 3.2 Turbo
  12. Gareth Halfacree
    4 Dec 2007
    New USB 3.2 Gen 2x2 XL.
  13. Anfield
    Anfield Multimodder
    15 Jan 2010
    Only acceptable if it comes with a red Turbo button:p
  14. Assassin8or
    24 Apr 2009
    But unless the 3.2 LB spec is cheaper to design and implement in silicon than 2.0 it'll never be used for these use cases.
    Type-C can be implemented on USB 2.0. My phone, and a hell of a lot of other phones, use exactly that as their charging and data port.
  15. edzieba
    14 Jan 2009
    No, you phone implements USB 3.1 using the High Sped data rate (rather than SuperSpeed).
    Which demonstrates my point: 'just keep the sold stuff and add the new bits we want to it' is exactly what the USB IF is doing, but they're not using the same name (USB 2.0) to refer to two completely different standards.
  16. Xlog
    Xlog Minimodder
    16 Dec 2006
    Most backward compatible standards do that, if USB3 was completely new standard with no backward compatibility we would have the same situation as with Thunderbolt - very few manufacturers would bother to implement it, because vast majority of users/devices don't really need it.
  17. RedFlames
    23 Apr 2009
Tags: Add Tags
