Networks USB or PCMCIA?
Discussion in 'Hardware' started by Squallers, 18 Dec 2009.
  1. Squallers
    Squallers Meat Puppet
    7 Oct 2008
    Having just knackered the USB wireless stick I use with my laptop for the nth time I'm getting a bit fed up of having to resolder the contacts
    Unfortunately it's an old laptop so my only options are another USB adapter or a PCMCIA card. I can honestly say that I've never used anything that goes in the card-bus before but from the looks of the pictures it would protrude less and looks more solid (so I'm less likely to break it). But I'm completely unfamiliar with the tech so would it be noticeably slower/faster (?) than a USB adapter or will it make absolutely no difference in my 850mhz P3 powerhouse of a laptop?
  2. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    Considering that lappy probably only operates on USB 1, I'd wager the PCMCIA slot would work much better (since it's essentially laptop PCI)
    As for plugging stuff in, it's just a really long, deep USB connector (sort of, not really), but you'll need drivers.
  3. Squallers
    7 Oct 2008
    Thanks man. Didn't think about the whole USB 1 or 2 issue, you're right it only has the first gen tech.
    PCMCIA it is then, definitely looks like it'll be harder for me to break.
  4. SwiftDestiny101
    SwiftDestiny101 Has a wire neatness fetish...
    23 Apr 2009
    :eyebrow:
  5. MaverickWill
    26 Apr 2009
    Well, it is! You take the card, and slot it in! Didn't really know how else to explain it, tbh.
    Maybe a comparison to an old Game Boy cartridge would have been better... :D
  6. Gareth24
    Gareth24 Folding = vdubs
    16 Jun 2009
    I have used both USB and PCMCIA wireless adapters in an old laptop nd in my opinion I have found the PCMCIA card to be better, simply because I haven't broken it yet. I broke 2 USB wireless sticks before switching to a PCMCIA nd won't be using a stick again.
  7. Squallers
    7 Oct 2008
    That's exactly the reason I decided on the PCMCIA (which i've now ordered). Up to now I've only had the one stick but the thing's been knackered and re-soldered several times (casing held together by tape) and this time I just couldn't be bothered, that and my soldering iron's at uni
