News USB Power Delivery Specification finalised
Discussion in 'Article Discussion' started by brumgrunt, 19 Jul 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Tyrmot
    Tyrmot Minimodder
    12 Mar 2008
    100W, pretty impressive
  3. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Yep, it's 10x what Thunderbolt can do. Though USB power delivery cables are bound to be thicker since they'll be pushing 20A at assuming 5V.
  4. Fruitloaf
    Fruitloaf Tinkerer
    5 Jun 2002
    I'm sure it'll take a number of years to filter through but I'm looking forward to it. Being able to cut down on the number of different sockets can only be a bonus even if you still need micro, mini and regular usb cables thats a huge step up from the huge number of different round, proprietary and different voltage connectors we have now.
  5. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    100w - should only take a few hours to charge a future smartphone. I cant wait for this to be implemented into laptops.
  6. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    A few hours to charge a smartphone? A few minutes! Assuming it doesn't explode. Compared the current, what, 3 Amps on the USB? I am curious, though. Would make USB3 portable harddrives even better.
  7. Bob1234
    Bob1234 What's a Dremel?
    30 Jul 2008
    900mA for USB 3, 500mA for USB 2, both at 5V.
    And yes, it would mean you could use possibly use 3.5" drives, although they need 12V as well as 5V, compared to the current 2.5" drives that need 1 cable for USB 3 or 2 if using USB 2.
  8. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    I was under the impression that iPhones would charge using 1amp from certain computers - and certainly from the wall?
  9. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    100w is stupid because most laptops won't be able to handle that, so if a device (such as a HDD) is designed to work with the 100w ports, it won't work on many mobile platforms.
  10. ch424
    ch424 Design Warrior
    26 May 2004
    Presumably the host and device negotiate how much power is available before allowing the device to draw anything. That's how the system works at the moment.
    Also, the USB-IF says that they achieve 100W by "using higher voltages and currents", so don't worry about it drawing 20A at 5V!
  11. Elton
    23 Jan 2009
    So now we'll be charging phones faster. And Laptops!
    Actually most chargers are ~100w these days. Not to mention that this specification does not mean it's constantly firing 100w worth of electricity (or 20A @ 5V) all the time at a product. I'm pretty sure they'd figure out a way to ensure that it would only output the maximum on certain devices.
    Plus this at least allows for more powerful chargers. Tablet owners would like this I'm sure.
  12. feedayeen
    feedayeen What's a Dremel?
    18 Jun 2008
    Since charging goes both ways, this is designed to power laptops too. They're really trying to use this as a logic compatible DC socket. Connect these sockets to a central computer and now you have a smart house! Larger devices can be outfitted with wifi/bluetooth support cheaply, but that wouldn't be efficient with light bulbs or similar devices.
  13. CyberAngel
    CyberAngel What's a Dremel?
    19 Mar 2011
    my laptop (hp-compaq) has a 90W charger, some has 65W
    but currently they are all different (all my laptops and those of my friends)
    USB 3.0+
    [LIKE]
  14. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    Good to know there's a handshake first - my first thought was that I'm pretty sure I don't always have 100w available to draw from my PSU...not that I foresee actually powering anything that would draw 100w from my desktop.
    Not sure about actual power figures, but yes. At least, it's been fairly common for Asus and a few other manufacturers to have a high-power USB port for fast charging of devices that support it, including iDevices.
  15. Bob1234
    30 Jul 2008
    They just charge slower from standard USB ports, although iPads dont charge at all, and power bricks are usually higher non-USB spec ampages.
    The spec amps are just those provided as a maximum from a computer port, not the maximum you can safely conduct over a cable.
  16. do_it_anyway
    do_it_anyway Minimodder
    24 Apr 2009
    Charge the laptop battery over USB! This sounds cool.
    In my family - of the 3, now broken, laptops 2 of them broke because the power input got wrecked with people yanking on the power lead and generally mistreating them.
    If we could charge via USB3 then a broken USB port is a pain, but at least your PC isn't an expensive paperweight afterwards. You just switch to another of the USB's. :)
  17. Bob1234
    30 Jul 2008
    Like that would happen, you just know that only one of the USB ports will be wired to the battery.
  18. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    I believe that at the moment USB ports supply .5A along the power lines unless the device/charger states that it can take/deliver more, this is done by shorting the data lines which in turn tells the device it can draw what it wishes, this is how the USB wall chargers work telling the device that it can draw as much power as it wants. Believe this is true for most devices bar apple who do something else to inform the device how much power it can pull.
  19. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    We're gonna need bigger 5V rails cap'n!
  20. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    I'd imagine this is going to mean an added 12v wire or something as drawing 20a @5V is going to require a heavy bit of wire...
Tags: Add Tags
