Storage USB Stick Question
Discussion in 'Hardware' started by crazyg1zm0, 28 Aug 2014.
  1. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    Hi All
    I have a handfull of These
    I simply want a way of making It so I can use this as a normal USB stick. I need to create 3 Boot-able USB sticks of varying sizes for some boot-able utilities I need to have for work.
    The issue is that the device is encrypted, so when i plug it in I have to run the device and put in a password which will then unlock the storage portion of the stick (this portion is only 4gb)
    So if anyone has any ideas on a way of making the stick useable im all ears. I don NOT care about the contents As I have 5 of these all brand new in packaging that I would idealy like to use, for most of them i would be happy with having 4gb of space Ideally if i can get all space thats great butnot a priority.
    If you have questions give me a shout
    Pete
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I think you would probably be best off to trade them to someone that would have a use for the encryption feature for some standard USB flash drives.
    It's hardware based, so the only way to stop it from doing what it does would be a hardware modification.
  3. crazyg1zm0
    20 Feb 2007
    Thats what I was thinking I just wanted to double check.
