News USB4 combines USB 3.2, Thunderbolt
Discussion in 'Article Discussion' started by bit-tech, 5 Mar 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. David
    7 Apr 2009
    Is that correct? Dual lane is 20Gb/s and TB3 uses four lanes for 40Gb/s. I spent a lot of time searching for a longer full bandwidth TB3 cable and encountered hundreds claiming to be just that until you dig down to discover they are "only" 20Gb/s cables.
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    The interesting part is only going to come when the actual spec is available, and we can tell whether this supersedes USB 3.2 (host Thunderbolt/DP/HDMI alternate modes supported-but-optional parts of the protocol) or operates in parallel as a 'high end' spec - basically replacing Thunderbolt 3 - to allow simplified branding of "USB 4 port is best USB port".
  4. Gareth Halfacree
    4 Dec 2007
    No, no it is not: it's the result of my misreading the, in my defence very badly phrased, following line:
    The fact the "using existing USB Type-C cables" is referred to by number of lanes and the "over 40Gbps-certified cables" is referred to by speed totally confuzzled my brain: in actual fact, they're saying you'll get 20Gb/s (or 10Gb/s, if you're not on USB 3.2 Gen 2x2) using two lanes on existing USB cabling and 40Gb/s requires new cables which are, presumably, four-lane and may or may not be any different to Thunderbolt 3 four-lane cables.
    I'll go fix, ta!
  5. David
    7 Apr 2009
    Wow, that was poorly phrased - you'd think they would try harder, given it's their job to promote it.
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    It did what it was supposed to do: confuse matters to make marketing easier. Can't break a promise you never made.
Tags: Add Tags
