username change
Discussion in 'Feedback & Suggestions' started by ShamWerks, 7 Sep 2016.
  1. ShamWerks
    ShamWerks What's a Dremel?
    5 Oct 2003
    Hello there,
    By any chance, would it be possible for an administrator to change my username from "dasham" to "ShamWerks" ?
    Many thanks! :thumb:
  2. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  3. MeMo
    MeMo It is what it is
    26 Jun 2016
    So it is possible??
    So you can change your user name!!:rock: Cool!
  4. GeorgeK
    18 Sep 2010
    You can if you ask a mod to do it (and the name isn't already taken obviously)
  5. MeMo
    26 Jun 2016
    Ok, thank you!
  6. Mojo
    Mojo Multimodder
    18 Nov 2011
    Can i possibly have mine changed to 'Mojo' please @Dogbert666 :)
  7. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Taken but by a banned member. Will have to consult with the powers that be.
  8. Mojo
    Mojo Multimodder
    18 Nov 2011
    Could change it to MojoMatt? @MLyons
  9. MLyons
    3 Mar 2017
    If by the end of my lunch i don't have a reply on a way i can get you "Mojo I'll change it to that.
  10. Mojo
    Mojo Multimodder
    18 Nov 2011
    Thank you :)
  11. MLyons
    3 Mar 2017
    So final answer is yes but I first need to do a bunch of testing in my dev environment as we haven't done this on the new forums/website yet. Do you login to the website at all or just the forums?
  12. Mojo
    Mojo Multimodder
    18 Nov 2011
    Typically just the forums :)
    But happy to be part of any testing needed :)
  13. MLyons
    3 Mar 2017
    OK. We've got a plan for testing First tests went well tonight will finish up tomorrow morning and hopefully you should have a new username by lunch
  14. Mojo
    Mojo Multimodder
    18 Nov 2011
    You guys are the best!!
  15. MLyons
    3 Mar 2017
    So quickly before i do this do you want the "Mojo" account or "MojoMatt" I can do either one.
  16. Mojo
    Mojo Multimodder
    18 Nov 2011
    Mojo would be bestest :)
  17. MLyons
    3 Mar 2017
    Ok I'll do it now. You'll login with the new username
    EDIT: Done
  18. Mojo
    Mojo Multimodder
    18 Nov 2011
    Wicked :)
    Thank you
  19. SkiDave
    SkiDave Minimodder
    16 Mar 2008
    Please could mine be changed to "SkiDave"?
  20. MLyons
    3 Mar 2017
    If you login to the website with the same account you will lose your preferences, Just a heads up. Will do it now.
    EDIT: Done. You now login with your new username
    SkiDave likes this.
