Modding Using a Key Switch to Power Up??
Discussion in 'Modding' started by Dazbo666, 16 Dec 2002.
  1. Dazbo666
    Dazbo666 What's a Dremel?
    16 Dec 2002
    I've been trying to find out about how to power up my PC using a key switch...
    I'm fairly new to modding, learning all the time, and need some advice from anyone who's already done this mod??
    I know I can buy them from Maplins among others, but just want advice on how it works / how to wire one up??
  2. linear
    linear Minimodder
    5 Oct 2001
    Welcome to the boards.
    You would ideally want one that is momentary. Then you just need to cut the lead off the one in the case, and connect it to your new switch. When the two wires are shorted together, your peecee will start.
  3. SilverBullet
    SilverBullet Banned
    14 Oct 2002
    Maplins sell buttons and things like that.
  4. Dazbo666
    16 Dec 2002
    Thanks for the welcome, and the advice.
    My idea was basically have a "child-proof" power switch.... cos I had a bad experience with a few mb's of files deleted from my PC recently:sigh:
    I don't want prying hands to be able to switch my PC on when I'm not there, and don't want to disconnect the wiring when I go out either?!
  5. linear
    linear Minimodder
    5 Oct 2001
    Ah, maybe that calls for a different answer.
    You can take any old key swtich (not a momentary, but the ones you get from auto parts stores etc.) and put it inline with the power button for a 'arm' control. With the keyswitch off, the power button does nothing (including while the peecee is running--they can't turn it off) but with it on, the power button is 'armed.'
  6. Dazbo666
    16 Dec 2002
    Now, that sounds pretty good!!
    I didn't particularly want to replace the original power button, but this way I could even re-route the wires to the back of the case, and "hide" the key switch?!
    Thanks linear :rock: :clap:
  7. Morphine
    Morphine weeee!
    23 Feb 2002
    I'm a paranoid freak, and dont particularly wantmy parents to be able to look at whats on my PC. Although if they ask me, then I will gladly show them around. Its just that when I do finally build this thing and pour so much time and money into it, I really dont want anyone else to be able to use it. So a key switch to "arm" my PC would own!:geek:
  8. The Savior
    The Savior What's a Dremel?
    28 Sep 2002
    Yes, you could definatly do that. Just find the wire that does to your power button and add in the keyswitch.
  9. disco volante
    disco volante What's a Dremel?
    22 Sep 2002
    I'd just prefer that mine don't find my porn stash.
  10. l33t_c0mput6r_m0dz
    l33t_c0mput6r_m0dz What's a Dremel?
    21 Sep 2002
    Whatever happened to setting a password to log on to the computer?? I think that would deter most nosy and computer illiterate (non hacking) parents :D
  11. Morphine
    Morphine weeee!
    23 Feb 2002
    but you see.... I can put that switch in an say "oh, but it came like that..." And how would they know?
    oh an ditto on the pron stash... :worried:
  12. Altron
    Altron Minimodder
    12 Dec 2002
    lol Morphine
  13. Morphine
    Morphine weeee!
    23 Feb 2002
    i just realized how comical that is, with the baby santa-monkey as my avatar... heh
  14. zackerouac
    zackerouac bring it
    23 Sep 2002
    :eeek: <doesnt wanna know whats in morphines pr0n stash>
  15. Altron
    Altron Minimodder
    12 Dec 2002
    EDITED for conent.
  16. m0nk3y
    m0nk3y What's a Dremel?
    25 Oct 2002
    I had planned on doing this just a little differently. Can't reveal anything at the moment but it will be soon... :clap:
    These are the momentary switches i was going to use:
    High quality, round tumbler type switch. Momentary N.O. 3 amp, 125VAC. Includes 2 keys.
    Linkage
  17. l33t_c0mput6r_m0dz
    21 Sep 2002
    jeez.. what some ppl will do to protect their ever-so-valuable pr0n stash :hehe:
  18. delphia
    delphia What's a Dremel?
    9 Sep 2002
    at a local lan a few months ago, a friend of mine leeched a guys pron.
    he found something like kiddie pron
    he grabed an admin and showed him
    the guy was arrested.
    however he escaped legal action cause the girls were of "questionable age" in otherwords, there was no way to determine definite age. so he was let off with a warning and a "if theres a next time, we will persue this further"
    (he was only 19 so even if they were a shade under 18 its not realy perverted, and he realy did seem shocked that the cops were arresting him over it )
    ****the moral to this story, J00R PRON C4N C0M3 B4K TO HAUNT YOU, GU4RD 17 \/\/17H J00R 1IF3, L33T 57Yl3****
  19. Dazbo666
    16 Dec 2002
    This thread starts out as a query about PC security, and ends up with a caution about kiddie pr0n ?? :sigh: :wallbash:
    Yes, you gotta be careful about what you store on your PC, and what sites you visit, but I've got an adequate firewall installed so that my kids can use my PC, and questionable material is no longer an issue.
    My main interest is actually forums, FPS games, and PC modding.
  20. delphia
    9 Sep 2002
    it wasnt realy a lecture, or caution.
    it was a true story that i turned into a joke :p
