Cooling Using LGA775 block on LGA1366 setup
Discussion in 'Hardware' started by ry@n, 16 Apr 2009.
  1. ry@n
    ry@n Minimodder
    31 Aug 2005
    Hey,
    I've just upgraded to an i7 setup and was wondering if there was any chance of me using my old "Danger Den MC-TDX 775" block on it? Im running the intel reference cooler at the moment and my 920 is idling at 38 degrees!!
    I can see that the mounting holes are wider apart on the new board so does anyone know of an adapter I can buy for this block or even a place to buy a replacement lucite top? If not, I will just have to buy a new block when I have the money.
  2. icutebluezone
    icutebluezone The meaning of life is to MOD
    6 Aug 2007
    Couldnt you just make a new lucite top to fit it onto a 1366.
  3. Guest-23315
    Guest-23315 Guest
    E-mail DangerDen and ask for one?
    Or ask Paul (Coolmiester) to make you one, as he's done a nice mount for 1366 in derlin.
  4. LockBreaker
    LockBreaker What's a Dremel?
    8 Nov 2008
    I'd say it's too hot. You won't be getting any good temps, not with that block. =)
    If you could afford it I'd recommend going with a Heatkiller v3.0 or a Swiftech GTZ. :)
  5. ry@n
    ry@n Minimodder
    31 Aug 2005
    Thanks for the feedback, I have been looking at some reviews and I think I will just try and sell my current block and danger den pump to a friend or on this forum and just buy new.
  6. samkiller42
    25 Apr 2006
    The EK-Supreme LT i7 is what i plan on purchasing, it's £34 from watercoolinguk.co.uk
    Sam
