Using Live CD to recover data
Discussion in 'Tech Support' started by beesbees, 31 May 2007.
  1. beesbees
    beesbees What's a Dremel?
    29 Apr 2007
    I appear somehow to have corrupted one of my hard drives. It can't be accessed in Windows Explorer, nor in disk management. Now this happened to me before, so I slyly plopped in my Slax LiveCD, and, thank god, the data was there. Now the problem - is it possible to write to NTFS in Linux? Or do I need to format my external hard drive to copy the data over. When I try now, it says wrong permissions, but I can't change the permissions.
    I suppose I could copy it all to DVDs, but thats a last resort!
  2. Krikkit
    21 Jan 2003
    As far as I know there isn't any Linux distro that can write to NTFS - you can read them, but not write afaik.
    If you don't have permission, try making a fresh install of 2000/XP with full permissions and see if it'll let you access it that way.
  3. beesbees
    29 Apr 2007
    I don't really think it's worth doing a clean install. To be honest, there's nothing irreplaceable on it, and the stuff that I really want or havent backed up recently I can put on DVD through Slax, ie Music ETC.
    So I'll do that and then reformat I guess...
    Thanks for reply.
  4. Krikkit
    21 Jan 2003
    No, no, not a clean install, another install, either on a new partition, or on a new HD altogether - you can dual-boot them, and then just delete the other when you've finished.
  5. krimson
    krimson What's a Dremel?
    16 Nov 2006
