News UT3: Limited Edition unveiled
Discussion in 'Article Discussion' started by CardJoe, 28 Sep 2007.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    PC, 360 and PS3
  2. Aankhen
    Aankhen What's a Dremel?
    15 Oct 2005
    Indeed it can, which is why I never mentioned resolution. :)
    Also, note that "higher resolution" != "better". It is generally better, but there's a point beyond which increasing the resolution simply increases the amount of squinting you do.
  3. wyx087
    wyx087 Multimodder
    15 Aug 2007
    true, true.
    but i find at 22inch, 1680x1050 is enough, whereas at 50inch, 1080p is a bit rough on the edges. really, resolution should increase with screensize. so 50inch should at least have something around 1600i.
  4. Aankhen
    15 Oct 2005
    I agree, though 1600i doesn't seem to be adequately large; I figure it goes 22" = 1,680×1,050, 30" = 1,920×1,200, 40" = 2,560×1,600, and 50" is, uh… 3,200×2,000 I guess.
  5. devdevil85
    devdevil85 What's a Dremel?
    29 Nov 2006
    Guys, I own a 96" InFocus 720p Projector and I have played a PS3 on it @ 720p and the games looked phenominal and believe me, I have a 19" flat screen monitor running at 1600 x 1200, so I know 'high resolution', too. IMO: Larger = better (but only when the propotion 'size to # of pixels' stays somewhat 1-1.....of course if the screen gets too big (and you only spent half as much as you should on the projector) you will see the pixels, but in my case if you sit far enough back from the screen, all you would see is crisp, clear, large video.....but I do understand you when you say higher pixels = better, but it's really a trade-off on what matters most to you? A larger screen with more noticable pixels/jaggies or a smaller screen with with 'almost impossible to notice' pixels/jaggies? Personally, I would still go with the larger screen due to the "wow factor"...
Tags: Add Tags
