UTMod 7-14-04 Final Pics.
Discussion in 'Project Logs' started by Sheldog23, 16 Jan 2004.
  1. Sheldog23
    Sheldog23 What's a Dremel?
    11 Jan 2004
    OK, Guys this is my first post in this sit so go easy. This is my latest mod which is still in progress. I still need to add lighting to the top and upgrade the components now that is working. I have updated a few tweaks since These pics such as adding a fan to the Video card and a Higher CFM fan to the CPU.
    Here is a link to the build page.
    http://www.austinpcmods.com/utMod.html
    there are a lot of pics there and I thought it was pointless to copy them all here. Here is the pics.
    http://www.austinpcmods.com/images.html
    I have added the Hyperlight and some white LED fans. Although it's color does not match the LED's. So I may have to change it over to some superbright LED's strategically placed. I will live with it a while and see. I also added a CD Drive button on the back of the case so I don't have to push against the faceplate of the cd to open it. The buttons on the face of the CD drive made my cover stick out in a strange way. Now it is more "stealthy". I did a lot of rewiring and stuff that you can't see. Also added a new 60gb hard drive. That old 8gb was to slow and was driving me crazy. I almost forgot I added the smartfan II and painted it silver from orange. Now at full speed my system stays at 27C and when I turn it down it still runs at only 32C. A big improvement from that junky old clear fan.
  2. a9on87
    a9on87 ...
    2 Nov 2003
    Liking this case a lot!
    Is the bit with the ports on the front then?
    Cool Idea - How did you make the acrylic case?
  3. kenco_uk
    28 Nov 2003
    That's the dog's danglies. Off to read your log now.
  4. planki
    planki ...
    20 Dec 2003
    im thinking a lcd screen modded into a clear plexi case would look fly man go for it
  5. vonkaar
    vonkaar What's a Dremel?
    6 Oct 2003
    Very original! Nice job ^_^.
  6. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    I noticed the water cutter in your project log.
    Where did you get that done?
  7. Sheldog23
    11 Jan 2004
    You mean This?
    http://www.austinpcmods.com/images/pics/utMod/making the grills.jpg
    It's actually an engraving machine. (basically a small CNC router) I work at a sign shop and I just create what I need. We have Giant plotters, printers cutters, a whole shop full of goodies. I don't why it took me so long to get into modding. I am kinda the opposite of most modders anyways, I don't really think about what goes inside, I am all about the case man. All that electrical stuff is just an afterthought. After I get an Idea I kinda go:"OK, now how do I make the stuff fit in?"
    Here is a Tut I made on bending acrylic. I made this case in a similar way just way...way more complicated.http://www.austinpcmods.com/Plex Bending Tutorial.htm
    [edit] Zap, don't you have a versa laser? Those own routers and waterjets.
    Oh, and a9on87 the setup is the LCD would be mounted(?) just on top of the cd and switches. That way from the sides you would see the guy and the back just the etchings. I am thinking of a clear plastic henge so I can lift the Screen up to show off the inside. Of course this is all just "In Theory".
  8. jpb
    jpb What's a Dremel?
    8 Aug 2002
    What he said!
    That's one creative and original case Sheldog. Great execution of your vision.
  9. ZapWizard
    19 Sep 2002
    Good guide, I may build one of those benders once I get room.
    My laser can gut plexi and wood just fine, but not metal.
  10. Sheldog23
    11 Jan 2004
    yeah, that's the bummer of an otherwise awsome machine.
    You can get waterjeting and Routing at Aquajet here in austin. They have crappy service though. You may also try a place called Let-R-Signs. The owner Dick Smith is a friend of mine and has cut a couple of things on his router table for me. He is a good old guy, just tell him it's for a computer and Sheldon sent you, he will nod knowingly.
    For you Modders here in Austin who need any kind of graphic work or special material modding (weilding, routing, custom applique) just let me know. I have worked in the sign business for a long time and have lots of contacts. I also work at the Fastsigns on Anderson Mill and could probably get you a price break.
  11. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    I like this alot.. probably the best ut2003 mod I have seen to date. :rock:
  12. a9on87
    a9on87 ...
    2 Nov 2003
    I see - thats a great idea! :rock: I thought you meant that you were just going to put the LCD screen into new casing :duh: (I didn't read it properly - too busy looking at the pictures! :lol: )
  13. richman
    richman What's a Dremel?
    17 Sep 2003
    that case is proper good i wish i had one well actually i dont becuase then i would have the same as you but you know what i mean.
    Good job
    Cheers
    Richman
  14. Hallq16
    Hallq16 What's a Dremel?
    30 Aug 2003
    Now that's what I call a truly original case! keep up the good work! :thumb:
  15. Incorpirate
    Incorpirate What's a Dremel?
    2 Jan 2004
  16. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    Definitely going to have to steal the idea for bending acrylic. Ive tried it using a heat gun and it was just way to inaccurate. Your method gives it the degree of control that I need. Thanks.
    Case is very sharp.
  17. Otto's
    Otto's What's a Dremel?
    16 Jan 2004
    :rock: Making a own case. For him/herself... :eek:
  18. Le Tordu
    Le Tordu What's a Dremel?
    16 Jan 2004
    wooh ! :jawdrop:
    Great acrylic bending work ! :rock:
    It's always nice to be original in a Lan Arena :thumb:
  19. piloux
    piloux What's a Dremel?
    12 Nov 2003
    i agree with this , amazing work with the acrilic :jawdrop:
  20. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    yeh, I saw that case around on some other sites. It's cool :)
