Windows Vanishing emails?
Discussion in 'Tech Support' started by Ryu_ookami, 27 Apr 2009.
  1. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    Both my partner and I use Hotmail but for some reason everytime she sends me an email its vanishing. It appears in her sent folder but it doesn't appear in my Inbox or Junk folder. It literally just never arrives. Shes sending it to the right address as we have checked that and if I use my secondary email address it arrives there with out any problems. This has been on going for about a week now. Does anyone have any idea what could be causing this and how to fix it.
    I'm also receiving all my other emails ok as is she.
    shes receiving any emails from me that I send
  2. hujambo_Bwana
    hujambo_Bwana What's a Dremel?
    2 Aug 2006
    Are you using a POP cliet (Thunderbird, Outlook etc) or web based? Can you send to her? If so, has she tried a 'reply to' rather than 'send new'?
    If she is using a cliet then check the SMTP settings, security (SSL / TLS etc) mail server and port.
    Jimbo
  3. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    in hotmail.. you check your junk folder? maybe put her address in the spam list on accident- should be able to put her back on your safe list
